STD Tuning Engine Bolt patterns, flanges, mounts etc
  • 4 Vote(s) - 3 Average
09-25-2013, 08:29 AM #1
Please do not post without a diagram of said bolt pattern.
09-25-2013, 09:00 AM #2
Who it be, what it do. I've printed it at 1:1 and eyeballing things the pattern is correct. I'll get a full fancy drawing with SBC and all that later, but if you're looking to home brew a 617 adapter plate this is what you're looking for.
[Image: gI6Th5q.jpg]
T3 to GT2056V. If I did it again I'd probably move all the GT bolts/inlet to the right and down 1/4"-3/8"
[Image: adapteriq7.jpg]
This post was last modified: 09-25-2013, 09:14 AM by Simpler=Better.
Duncansport
01-23-2014, 03:41 PM #3
605/602 lower main girdle
.pdf
605 602 girdle.pdf
Duncansport
.pdf
605 602 girdle.pdf
fcp
02-18-2014, 07:37 PM #4
After some months, I am pleased to be able to include the files here to allow you to fabricate adapter plates to match the OM606 bellhousing to the BMW GS6-53DZ transmission (late model version, 2009 or so on).
The files included are complete PDF drawings for both sides of the plate. I have a Solidworks e-drawing file (you can download edrawing viewer for free online) so you can see how it all goes together and some DXF files for those that can use them. This site won't let me post them here it seems (maybe a mod can help out?), I'll find some way to list them though so people can get to them.
At the time of writing (Feb 18 2014), these are version '2.5-Final' and I believe them to be correct, but I will designate them 'RC1' (as officially a pre-release official version) until I get some feedback from others that they are OK, at which point I'll re-publish a final version here.
For those who aren't interested in this gearbox (which incidentally requires custom clutch/ flywheel) the OM606 bellhousing pattern will have other uses for members in the community I hope :-)
If you create derivative works from these drawings, please make sure you upload them for others to benefit from.
Now the important stuff!
These files are released to the community with the following disclaimer:
I make no warranty, guarantee or assertion in any respect of this design, its suitability or appropriateness to the use to which you may put it. If it breaks, blows up your engine, destroys your gearbox or in any way harms or endangers life limb, property or your sanity then by making use of this design (or any derivative) you accept full and entire responsibility for any consequences!
I make no guarantee that the measurements herin contained are correct, or that the approach or techniques used to design or transcribe the designs are correct.
I am NOT an engineer and if you are in any way unsure of the suitability of the design for your purpose you should consult someone who is!
Please note, no assertion is made in regard to title or use of original designs, IP or proprietary information which resides with the respective property rights holders. Citing 'Fair Use', these designs are released to the community for informational, educational, NON COMMERCIAL purposes and you should seek professional legal advice if any any doubt.
Thanks to everyone here are elsewhere who helped me with advice and opinion on this design. If you want to see the progress I am making, please see my Flickr account
Please post pictures of any project you use these on too Smile
Finally, if you like the design and find time, do send me a postcard to say hi from wherever you live: NowWeComply, Cody Technology Park, Old Ively Road, Farnborough, Hampshire, GU14 0LX, UK.
Have Fun Smile Ben
This post was last modified: 02-18-2014, 07:45 PM by fcp.
"Moderation is a fatal thing. Nothing succeeds like excess." Oscar Wilde
fcp
Have Fun Smile Ben
Duncansport
02-19-2014, 12:45 PM #5
(02-18-2014, 07:37 PM)fcp After some months, I am pleased to be able to include the files here to allow you to fabricate adapter plates to match the OM606 bellhousing to the BMW GS6-53DZ transmission (late model version, 2009 or so on).
Have Fun Smile Ben
Nice work, looks great
Duncansport
Have Fun Smile Ben
05-23-2014, 08:15 AM #6
[Image: 000-0000-002.jpg]
Standard OM606 + 605 exhaust manifold turbo outlet flange (hole drawn to 50mm, would require manifold hole grinding out to suit).
[Image: 000-0000-001.jpg]
Holset HX35 (T3) manifold flange dimensions. (The drawing is actually of a quick spool valve I am developing).
This post was last modified: 05-23-2014, 09:41 AM by Hario'.
F.R.A.S
05-24-2014, 01:49 AM #7
Here is the exhaust flange for om604/605/606 (cut to length).
I hope I've got all the important number on it.
Edit: Width of the ports are 74mm.
This post was last modified: 06-01-2014, 01:23 AM by F.R.A.S.
F.R.A.S
Duncansport
05-24-2014, 02:33 PM #8
(05-24-2014, 01:49 AM)F.R.A.S Here is the exhaust flange for om604/605/606 (cut to length).
Great! Thank you!
Duncansport
Great! Thank you!
F.R.A.S
05-24-2014, 04:20 PM #9
No problem. Just let me know if I forgot something...
Think about the fact that I've not measured in the center of the bot holes. The program was a bit pissed on me (I modified our special flange to just show the standard flange pattern) so I had a hard time making this Tongue
(05-24-2014, 02:33 PM)Duncansport Great! Thank you!
F.R.A.S
Tito
05-31-2014, 05:08 PM #10
Could be me but I can't find the width of the exhaust port? Tongue I anybody has a cad drawing would make me very happy. Wink Or i'll just copy the top drawing in solid works.
This post was last modified: 05-31-2014, 05:09 PM by Tito.
Tito
F.R.A.S
06-01-2014, 01:27 AM #11
Tongue you see, hahaha... Thanks mate. 74mm is the width of the port.
50mm is the straight area, that means that the radius in the end of the port are 14mm witch also determents the port hight of 28mm Cool
(05-31-2014, 05:08 PM)Tito Could be me but I can't find the width of the exhaust port? Tongue I anybody has a cad drawing would make me very happy. Wink Or i'll just copy the top drawing in solid works.
F.R.A.S
08-11-2014, 02:38 PM #12
617 block, small block chevy bell. NV3500, Muncie, etc. should fit this. The holes have been printed out and eyeballed on a desk, everything looks pretty darn square. The starter location is TBD-I'm going to try and squeeze a 617 starter on there somewhere.
The center cutout is 4.5"x4.5", the om617 pins are 12mm, the SBC pins are 1/2"
You will need to drill the 617 crank pattern on an 86+ (single piece rear main seal SBC) flywheel. The om617 crank pattern is twelve 10mm holes evenly spaced on a 103mm diameter circle. This should fit inside the 86+ SBC flywheel pretty easily.
I'd still reccomend checking the bell housing's center with a dial indicator, and using offset pins to center it all once assembled.
This post was last modified: 08-12-2014, 01:34 PM by Simpler=Better.
.dxf
617SBC.DXF
.dxf
617SBC.DXF
08-12-2014, 01:33 PM #13
VW TDI 4cyl to SBC
The funky inner profile is a rough sketch of the TDI block
You could definitely get away with cutting it down to about half size, but it's nice to have the full pattern for sizing.
.dxf
TDI4 SBC.DXF
VW TDI 4cyl to SBC
.dxf
TDI4 SBC.DXF
MrHope
12-30-2014, 12:27 PM #14
Did someone have a dxf file for t3flange and 606exhaust ?
W124 300D 1985 (daily driver)
MrHope
Tito
12-30-2014, 01:00 PM #15
I have a dxf of a 606 manifold. Only need to export the t3 flange (hx40s is t3 right? So confusing Big Grin) to dxf.
I used F.R.A.S 's drawing and checked with my own sliding gauge. I haven't had the flange cut yet. You can get it from me but it hasn't been tested to fit (little that could to wrong I think?)
Tito
F.R.A.S
12-30-2014, 05:19 PM #16
OM606 in DXF, sorry for not posted it before.
.dxf
OM606 FLÄNS.DXF
Here's a divided T4 flange for you guys.
.dxf
T4-divided.DXF
This post was last modified: 12-30-2014, 05:23 PM by F.R.A.S.
F.R.A.S
.dxf
OM606 FLÄNS.DXF
.dxf
T4-divided.DXF
F.R.A.S
01-01-2015, 06:52 PM #17
Alright guys, here is a DXF file of a divided T3.
.dxf
T3-divided.DXF
F.R.A.S
.dxf
T3-divided.DXF
12-12-2016, 10:07 AM #18
Does anyone have a DXF of a Holset HX/HY35 outlet flange/ Otherwise I will have a go this week
hents99
12-12-2016, 10:30 AM #19
This one?
With or without WG hole?
Or round flange with 6 holes?
With WG hole
https://www.upload.ee/files/6444071/hx35...g.dwg.html
WG hole blocked
https://www.upload.ee/files/6444074/hx35...d.DXF.html
This post was last modified: 12-12-2016, 12:38 PM by hents99.
www.elbe.ee - MB performance parts.
hents99
This one?
With WG hole
WG hole blocked
12-12-2016, 01:20 PM #20
(12-12-2016, 10:30 AM)hents99 This one?
With WG hole
WG hole blocked
YEs!  Thanks again Hendrik!
With WG hole
WG hole blocked
Knudsen Built.
01-10-2017, 11:28 AM #21
Hi
First, if this is the wrong place to ask so please refer to the right place.
Re: OM 60? and OM 648 (320 CDI) front cover.
I would, if possible, move OM 60? front cover for OM 648th
Reason: I want the fuel pump sitting on the side instead of the front.
Everything else is not important. The engine will be used with a Toyota gear box in a completely different car. Hence everything must be built.
Thanks in advance for help. No need to buy various engines without knowing if things can be moved.
Greetings
Knudsen Built.
Knudsen Built.
Hi
Greetings
Knudsen Built.
Om606w201
03-07-2017, 10:49 AM #22
Does anyone have dimensions or drawings of the OM606 flywheel / Crank bolt pattern.
Having a flywheel made and it would make this go a lot fast with these few measurements.
Thank you
Joshua
Om606w201
Thank you
Joshua
hents99
03-07-2017, 11:00 AM #23
I do have crank bolt pattern. I got your email and I will send you dimensions.
hents99
Om606w201
03-07-2017, 03:20 PM #24
Your a savior Hendricks!!
Thank you
Om606w201
Thank you
jhw.
10-21-2017, 09:11 AM #25
Does anyone have the bolt pattern of this style bmw zf box?
http://www.ebay.co.uk/itm/Bmw-e46-320d-1...SwjoVZ30lH
jhw.
tomppaz
11-09-2017, 03:47 AM #26
(03-07-2017, 11:00 AM)hents99 I do have crank bolt pattern. I got your email and I will send you dimensions.
It would be a good idea if you would share om606 crank bolt pattern in this thread. Thanks !
tomppaz
CRD4x4
CompoundSuperTurboDiesel4x4!
399
11-09-2017, 05:43 AM #27
(11-09-2017, 03:47 AM)tomppaz
Yes! Please! I've been looking for this bolt pattern for years w/o success & would love to have it!
CRD4x4
Langstrom
02-09-2018, 09:00 AM #28
Hi! I am in the need of dimensions of the OM606 Flexplate/automatic flywheel. So, If anyone happens to have one of these laying around, I would really appreciate if you could provide me with the following measurements! Smile
[Image: gUE5zZL.png]
//Johan
Langstrom
//Johan
kaputnik
02-27-2019, 02:59 PM #29
Did someone verified the OM606 pattern from FCP ? Are the coordinates all good?
kaputnik
jav1
02-27-2019, 03:50 PM #30
I used this numbers for the engine side of my adapter. Seemed to line up fine.
jav1
Granfatherglock
05-01-2019, 08:27 PM #31
Does anyone have om603 exhaust flange?
Granfatherglock
benjy_b
11-21-2019, 02:21 PM #32
Has anyone got a file for the OM605/606 motor mount pcd?
benjy_b
300SD81
12-15-2019, 10:22 PM #33
Haven't been around here in quite a while, but I'm putting my old OM617 to use as a generator.
Made up some adapters for generator usage (electric water pump, oil filter relocated for easy IP access, shaft output) so these might be useful.
Oil filter relocation
[Image: ix2XUK6.png]
Thermostat housing
[Image: KXWjeCX.png]
Water Pump
[Image: 94Qtv1V.png]
Crank bolt pattern
[Image: nzVENne.png]
Fusion 360 makes it really easy to reverse engineer the patterns. Place the part or gasket along with a machinists ruler on a scanner, import as canvas, scale using the ruler and have at it.
I have a waterjet cutter now, so if anyone needs custom flanges, shoot me a message.
This post was last modified: 12-15-2019, 10:38 PM by 300SD81.
Ich liebe meine Autos!
300SD81
Thermostat housing
Water Pump
Crank bolt pattern
nastala
05-12-2020, 10:32 PM #34
I've made the manifold gasket for the OM617, it should be accurate to within .2mm. It was done in Solidworks, and I included the .sldprt and a .dxf. I couldn't attach them for some reason, so here's a link to archive.org for them.
https://archive.org/details/om617manifold
nastala
HighFive
02-13-2023, 07:01 AM #35
Hi!
I wonder if someone has to share the bolt pattern between OM 601 (2.0d) and manual gearbox?
I'm planning to salvage this motor of mine and use it as a trusty workhorse for a power generator, but need to build a flange / adapter between the two.
The generator has a SAE flange so I know that pattern, but could not find 601's pattern and ran into this thread.
Thanks!
HighFive
Hi!
Thanks!
