STD Tuning Engine OM605 shaking
OM605 shaking
OM605 shaking
addi.bigg
OM605; 7,5mm elements
94
11-29-2017, 12:43 PM #1
Buddies,
My OM605 shakes sometimes at idle. I couldn't define any exact status when it is doing that, it also happens cold and hot, no matter how much I've driven before. Just one thing maybe, when I stop at the traffic light it may not shake but after a 20-30 seconds it can start also. What do you think what should I take a deeper look on? Nozzles?
OM603 mechanical pump, 7,5mm elements. Pump has been restored not much ago. Timing is on the original signing.
Thanks!
addi.bigg
Buddies,
Thanks!
addi.bigg
94
11-29-2017, 12:50 PM #2
(11-29-2017, 12:43 PM)addi.bigg Buddies,
Thanks!
The engine has a voice at idle like in this video at idle.
https://www.youtube.com/watch?v=cmDAwMYEBGU
addi.bigg
Thanks!
whipplem104
11-29-2017, 01:44 PM #3
If it is intermittent then it is your pump. Probably a delivery valve sticking.
Sounds like a modified pump.
whipplem104
addi.bigg
94
11-30-2017, 01:10 AM #4
(11-29-2017, 01:44 PM)whipplem104 If it is intermittent then it is your pump. Probably a delivery valve sticking.
The pump has 7,5mm elements. It is in good condition, also the power is perfect.
The pump has to be disassembled to cure sticking valve if that is the problem?
This post was last modified: 11-30-2017, 01:15 AM by addi.bigg.
addi.bigg
starynovy
11-30-2017, 05:43 AM #5
No, just delivery valves which are on top. So no further dismantling is needed no calibration.
starynovy
Fishman
11-30-2017, 06:26 AM #6
Can a sticking valve do any harm? Mine does the same up to 1500 rpm than smooths out.
Fishman
addi.bigg
94
11-30-2017, 02:42 PM #7
(11-30-2017, 05:43 AM)starynovy No, just delivery valves which are on top. So no further dismantling is needed no calibration.
A few drops of engine oil inside?
addi.bigg
starynovy
11-30-2017, 05:35 PM #8
Nope.. it is submerged in high pressure diesel so oil will not help. If it would stick you can lap it or change it.
starynovy
erx
w202 om606
323
11-30-2017, 05:57 PM #9
Usually delivery valves don't stick, they just fail due to careless pump installation when dust gets in from fuel lines and even smallest dust can ruin delivery valve seat or even element tip. If it sometimes runs smooth then maybe dust particle is stuck in valve seat and maybe it just needs cleaning. Try to loosen injector lines one by one at idle to make sure which cyl is problematic.
erx
baldur
Fast
509
11-30-2017, 07:05 PM #10
I've seen the delivery valve springs break.
Baldur Gislason
baldur
Baldur Gislason
Fishman
12-03-2017, 04:58 AM #11
Anybody got the part nr for the seals?
Fishman
baldur
Fast
509
12-03-2017, 09:03 AM #12
(12-03-2017, 04:58 AM)Fishman Anybody got the part nr for the seals?
This is where I always get them from:
https://www.ebay.com/itm/BOSCH-diesel-pu...2749.l2649
Baldur Gislason
baldur
Baldur Gislason
addi.bigg
94
12-14-2017, 01:18 PM #13
Trying the Liqui Moly (Lubro Moly) Diesel Purge cleaning would worth anything? Both for pump and nozzles. Ideas?
This post was last modified: 12-14-2017, 01:19 PM by addi.bigg.
addi.bigg
addi.bigg
94
01-08-2018, 03:08 PM #14
Actually I think the delivery valve really sticked as ione of the cylinders didn't run for a 20-30 seconds in idle, and after that started again.
The diassembly to clean the delivery valve means what this guy shows, so untight the upper side and clean everything above the copper washer?
https://www.youtube.com/watch?v=PlB0Uc1qdUk&t=389s
addi.bigg
 13 Guest(s)
 13 Guest(s)
