STD Tuning Engine OM606 intake manifold and turbo question
Antonio
02-07-2018, 08:21 AM #1
ive seen that om606 intake manifold can be fitted to om605 head and wondering what is the best option when cutting and welding.
Is it 4th cylinder that needs to be removed, where to cut, what is the best option
OEM 606 turbo rebuilt and balanced by pros is capable of runing for how much boost? i have 6mm 100cc pump set by dieselmeken and i want around 200-240hp, how much boost are we talking about and 606 turbo should be good for that much power?
at the moment i cant try because there is alot snow on the road
Antonio
Evgeniy1987
02-07-2018, 09:31 AM #2
It is probably impossible to destroy the 606/605 with a 6mm pump, unless you really screw up timing
Shortening the 606 manifold to 5 cilinders - good question. As far as I know, 4th cilinder is removed. I know that removing the 6th cilinder results in impossible-to-fit-in-car part...
Evgeniy1987
Antonio
02-07-2018, 09:45 AM #3
didnt think you understood...  om606 stock turbo is capable of how much?
Antonio
STDGer
02-07-2018, 01:46 PM #4
dont go for the 606 intake. on the thermal site alu is shit against pe.
ex 04. 1997 w202 om605 sedan ,Dieselmeken 7.5mm, 3" exhaust, he351w, 716.657 ca 350+ hp
actual 08. 1997 w202 om605 station wagon, oem edc pump, modded exhaust manifold, t04e turbo, oem pipe 1 silencer wannabe as much as possible
STDGer
awsrock
300SDL / HX30 / 90cc
179
02-08-2018, 11:40 AM #5
Somebody on here dyno'd 254 hp with 93cc on a 605 using a GT28, so you should be able to do 220-240 with 606 turbo.
awsrock
