Prechamber Mod "Flame" Front
(05-13-2016, 07:06 PM)Torkey Put the car on the dyno after reamng out to .125" on all the holes except for the drain and the large hole. Results were 13 more ft/lbs torque, 3 more HP. I recommend doing this. Quick, easy and cheap way to get more go.
The timing was advanced a few degrees. I'm not exactly sure how much though. I advanced it until it sounded right. Not a scientific method.
Soooooo, MB100 upper PC with 617.95 fire duct would be the ideal? They're pretty rare though, what if you had a Late 602/3 upper PC and rotated it. You'd need some jig to do it properly...and special welding rods I guess. Also would need a lathe to clean things up....
The 606 one seems to be designed for central mounting in the cylinder, not the best idea for use in the older engines? Wonder where the GP hole is etc. And if the upper part would fit in the older engines
Scott
there is no gain in changing the pre cups of your 617 A engine.
If your engine is 617 N/A u have a lot of things to change before reaching needs of best suited cups....
As of my experience the 605/6 injector wich uses the famous 315 nozzle can be used as drop in . Pre cup work best with around holes opened by 20/100 and the neck to 8mm , but this for turbo cups.... the na cups are too week to mod.
Good luck.
One day, I hope to soup up a 617 to 300-400hp..my NA conversion is just practice at this stage...(although I do have 315 nozzles in it)
The 605+6 have all the angled injection already, I think retrofitting angled injection PCs into a 617 would get a touch more efficiency out of the old dog as well as the enlarged burn holes
hehe, the seat of the injector at 15º angle is more a aesthetics and practicallity mixed with german ingenuity and ability to complicate than anything else, the 606 cups can´t be used in a 617 or in a 603 head unless heavy mods are done , so i belive it does not worth the assle...
regards
(05-19-2016, 09:10 PM)NZScott One day, I hope to soup up a 617 to 300-400hp..my NA conversion is just practice at this stage...(although I do have 315 nozzles in it)
(05-20-2016, 10:54 AM)barrote hehe, the seat of the injector at 15º angle is more a aesthetics and practicallity mixed with german ingenuity and ability to complicate than anything else, the 606 cups can´t be used in a 617 or in a 603 head unless heavy mods are done , so i belive it does not worth the assle...
regards
regards
Haven't quite got to that stage yet - car isn't running...
FWIW later 603s got the angled injection as did the 616. Good point about whether it's worth the hassle though- you never know til you try I guess?
I always felt like the angled injection engines run smoother and smoke less...
(05-22-2016, 09:03 PM)MFSuper90 I've got 315's, and the power increase is hardly noticeable if any.
Can anyone give me some advice how to drill bigger holes in these prechambers? Have tried after some help, but drillbits can not handle 606 prechambers.
Have tried to heat them red hot then let them cool slowly down. After that i tried with quality cobolt drill bits 2.5mm (holes is 2.2mm) that is designed for stainless steel drilling but they gets round almost right away. I am drillig at very low rpm
(05-27-2016, 04:09 AM)EDH_Performance Can anyone give me some advice how to drill bigger holes in these prechambers? Have tried after some help, but drillbits can not handle 606 prechambers.
I tryed several different drills. Untill i went to the local tools shop an bought reamers. After that it took me 20min do drill my chambers. But i only enlarged every second hole to 2,4 or 2,5mm according to the Suomi tuners recommendations.
But my engine is a Turbo so i have bigger holes then N/A engines from factory.
somewhere in the previous threads i explained how it can be done easy and cost efective,
since people can´t loose some time Reading , here it goes again,
"durasteel" bits or "carbide" i have access to a brand called "maykestag, 6,000 rpm for 2.5mm .
but the best is use a portable hand drill , those battery type, use care this bits can be sharpened if need be, since they are very hard the may brake easily , but nothing that a half skiled tech can´t handle.
BTW the moderator could post a thread on how to drill cups , wich type of holes people use.. dadda those fancy things
Yep. Whether burrs, bits, or reamers... carbide is the way to go. I reamed mine with carbide reamers to the proper diameter, then conically "ported" them with a carbide burr. All in all 25 bucks on ebay.
(11-25-2015, 12:43 PM)Captain America(11-25-2015, 11:42 AM)MTUPower How big did you enlarge the holes to? How temps have you seen on your EGT? For how long? How much fuel are you putting in? Which all leads to - why do you think your head has cracks? ...and lastly- if the engine is running fine are you going to reinstall the head or a buy a new one?
3 Front holes are at .203
2 Rear holes are at .157
Bottom Hole at .126
Highest temp Ive seen is right at 1250f for a few seconds, and that is right before the turbo is spooled (running 16 psi with pump turned up by me)
Making a looooooooong pull temps sit at just over 1200f
the engine got hot a few times enough to boil water out of the reservoir tank that may have done it. that's the only thing I can think. I will acquire a new head and port it
Bottom Hole at .126
Mmmmmmm nice. You yanks are so lucky to have lots of these engine lying around that you can do experiments like this.
Looking forward to some test results...
....so
How have they gone?
I got a random thought about trying something like this, if only I could find some cheap as NA (post about 1979) prechambers
(02-01-2018, 11:27 PM)NZScott ....so
How have they gone?
How have they gone?
Well that's a pleasant surprise, think everyone was counting on them running like crap. Think everyone now wants to know the power gain this gives...
(02-06-2018, 05:58 PM)R-3350 i would be interested in the effects with much more fueling. also would be interested in the BSFC with the new chambers.
i just wonder how they would handle a 2-3X increase in fueling. they may behave in a non linear way much past stock fueling. still its quite nice to see its working as intended i may be tempted to try these at some point.
(02-09-2018, 10:47 AM)R-3350 i just wonder how they would handle a 2-3X increase in fueling. they may behave in a non linear way much past stock fueling. still its quite nice to see its working as intended i may be tempted to try these at some point.
i have been following this thread and your work closely so i am aware of the mods you have shared publicly at least. my concern circles around what would they behave like/do if fed 175cc/1k fueling with boost to match? while i am loathe to agree with FI in any manner i do have some concerns about the thermal rejection and integrity of these if subjected to significantly more than stock fueling and boost and the associated temperatures and pressures. that being said i would still try them i would just likely wait till the long block i am assembling is finished in case it lunched itself due to dropping a tip or burning a piston. all that aside i have to commend you for you work and the interesting progress you have made.
So let me get this straight. You had to add timing with this mod? If so then you are slowing down the flame front. Or effecting quench.
I do not see how this is a good thing..
(02-11-2018, 01:00 PM)whipplem104 So let me get this straight. You had to add timing with this mod? If so then you are slowing down the flame front. Or effecting quench.
My point is that if you are having to run increased timing that you are slowing down the flame front. The fact that you are increasing timing means that you are taking longer to reach peak cylinder pressure. So I do not see how the mod is doing what you want, assuming you want more power. If your flame front was faster from the larger holes then you should decrease timing.
I had assumed that the larger holes were allowing a larger amount of fuel to burn at a quicker rate. Because the holes were to small and causing a restriction for the volume.
while i would agree that timing is best kept as little as is practically possible. i am not entirely sure that this is slowing down the flame front. i suspect that with it being closer to DI that it is experiencing more of an ignition delay like most other diesels. the PC impingement ball tends to cancel most of that delay at operating temps in the standard PC. but potentially with this opened set up it could be running a bit cooler so it takes a bit of time to get going while still increasing the combustion propagation speed into the chamber. thats why i was wondering about the BSFC it should be relatively evident if the BSFC goes up appreciably that the slower combustion Delta P means more time spent BTDC fighting it reducing efficiency. in a gas engine the less timing needed the better the burn however you don't have to factor things like ignition delay and PC to main chamber transfer times so im still watching this to see the results in data.
(02-13-2018, 10:15 AM)whipplem104 My point is that if you are having to run increased timing that you are slowing down the flame front. The fact that you are increasing timing means that you are taking longer to reach peak cylinder pressure. So I do not see how the mod is doing what you want, assuming you want more power. If your flame front was faster from the larger holes then you should decrease timing.
So you are saying that the holes are enough of a restriction to keep the prechamber from reaching compression ignition as fast as the rest of the cylinder? So with larger holes it gets there sooner and you can start injection earlier because of this? And this is good for a more complete combustion and it does not shift peak cylinder pressure. Rather than speeding up actual combustion speed and the rate at which the flame front enters the combustion chamber.
I would think that you would want a cam specifically designed for the injection pump for this in order for it to be of benefit?
(02-13-2018, 02:44 PM)whipplem104 So you are saying that the holes are enough of a restriction to keep the prechamber from reaching compression ignition as fast as the rest of the cylinder? So with larger holes it gets there sooner and you can start injection earlier because of this? And this is good for a more complete combustion and it does not shift peak cylinder pressure. Rather than speeding up actual combustion speed and the rate at which the flame front enters the combustion chamber.
It's pretty interesting though that it wants advanced timing. It goes againstexperience in DI and IDI engines. DI engines often run timing as low as 5-10 degrees BTDC, up to 20 degrees BTDC. Swirl and prechamber engines are similar and run timing advanced compared to DI - 20-30 degrees BTDC.
I really want to hear how the engine sounds with the modified prechambers. Make a video if you can. Does it still have the specific sound of MB prechamber engines ?
(02-14-2018, 05:09 PM)Petar It's pretty interesting though that it wants advanced timing. It goes againstexperience in DI and IDI engines. DI engines often run timing as low as 5-10 degrees BTDC, up to 20 degrees BTDC. Swirl and prechamber engines are similar and run timing advanced compared to DI - 20-30 degrees BTDC.
I think I am going to try advancing the cam 4 more degrees for a total of 14* advanced over stock and see what that does.
I like what the 10* did for me, and by the way it runs, I think there is more to be had by advancing it a little more. I think one tooth is 20* but I need to confirm that. I also want to check for valve clearance, so I will advance the cam one tooth on a donor engine I have and see how much intake valve movement there is first.
Also getting ready for a bigger turbo and advancing the injection timing to 30* BTDC.
From the testing that other members have done, there is definitely a difference in the set up for a "restricted PC" (with holes) and with an "open PC" (Open slot).
I just bought a wagon block with the head and it's sitting in the grosch. My current PC's are enlarged but I think I'm going to pull the ones in the "new" block and make them even more enlarged. The head's intake ports will be enlarged as well as the exhaust ports and with all this timing will be advanced even more than it is now. More air to get in and out should see the engine more responsive and make more power.
(03-09-2018, 06:31 AM)MTUPower I just bought a wagon block with the head and it's sitting in the grosch. My current PC's are enlarged but I think I'm going to pull the ones in the "new" block and make them even more enlarged. The head's intake ports will be enlarged as well as the exhaust ports and with all this timing will be advanced even more than it is now. More air to get in and out should see the engine more responsive and make more power.
There are 40 teeth on the cam gear, so each tooth is worth 9 degrees at the cam, 18 degrees at the crank. I advanced the cam one tooth on a donor engine, and checked for valve clearance. There was interference at the intake valve that prevented rotation. Right now I am running the cam advanced 5 degrees at the cam which is 10 degrees at the crank and that is all that there is to be had.
Anyone who is looking at a custom cam should really be careful. The valve relief pockets need to be made deeper if any significant changes in cam geometry are being considered.
If anyone has a bad 617a piston, I would be interested in it to cut apart to see how much deeper I can make the valve relief pockets without making the piston too thin, (I have no idea what the oil cavity looks like).
I wanted to advance the cam another 5 degrees at the crank, but there is no way without cutting the pistons.
