DSL1 controller
DSL1 controller
(09-26-2017, 09:49 AM)CutWeldDrive hi Baldur,
is there an IP rating for the controller.
is it safe to place in engine bay or is it best to place inside vehicle
thanks
thanks
(09-26-2017, 01:31 PM)jav1 Baldur-
I'm reading that the om606 needs tabs on the flywheel for crank position... is this correct even with the DSL1? I'm trying to go manual transmission and want to know if I need to address that on the flywheel.
I have made another firmware release, version 1.16 today.
Notable improvements:
- Throttle response is now filtered by an exponential decay filter that allows smoothing of torque increase and decrease configurable independently for improved drivability and less transient smoke.
- There is now a configurable strategy for dealing with engine speed oscillations on manual transmission cars with modified injection pumps.
- I have implemented OBD2 communications over CAN bus. This enables the use of aftermarket gauges that connect to the OBD2 port, mobile phone and tablet apps such as Torque that can display OBD2 data, and reading error codes reported by the ECU can be done by any OBD2 scantool, aiding diagnostics when a laptop with the Calibrator software is not at hand.
OBD2 code reader reporting software version:
Cheap (25 US dollars) OBD2 heads up display that shows engine speed, vehicle speed and engine temperature:
I have released firmware version 1.17 now.
Most notable improvement is that now every single configuration option is documented in the config. So whenever editing a single configuration variable, a description of it is displayed on screen. When editing a function or map, the description can be brought up by pressing the F1 key on the keyboard twice.
I have also been testing for the past week with a modified injection pump in my car. Barrote built me a 7.5mm pump with Dieselmeken elements. After spending some time tuning it now drives almost as smooth as it did with the 6mm pump but of course makes much more power.
(01-21-2018, 03:56 PM)baldur I have released firmware version 1.17 now.
Current DSL1 user here on my OM606 swap. (build thread --> https://forum.ih8mud.com/threads/white-l...338/page-2). My setup used a stock IP and turbo. The only difference is the 3" exhaust, larger intercooler, and the fact that I've given up on the vacuum controlled wastegate actuator. I think once I've gotten the turbo a bit more controlled I'll be able to reduce the smoke while driving around. That said I've been getting a lot more smoke (not blue or white) at idle than i'd like and the driveability has been very touchy. I've gotten it a bit better by messing with some of the maps/anti stall settings. Have others on here running the stock turbo and IP been making many modifications to their fuel/idle maps? / Can this thread be a good one to post config files, discuss changes to improve tuning using this ecu?
(02-22-2018, 12:25 PM)X Double Dot Current DSL1 user here on my OM606 swap. (build thread --> https://forum.ih8mud.com/threads/white-l...338/page-2). My setup used a stock IP and turbo. The only difference is the 3" exhaust, larger intercooler, and the fact that I've given up on the vacuum controlled wastegate actuator. I think once I've gotten the turbo a bit more controlled I'll be able to reduce the smoke while driving around. That said I've been getting a lot more smoke (not blue or white) at idle than i'd like and the driveability has been very touchy. I've gotten it a bit better by messing with some of the maps/anti stall settings. Have others on here running the stock turbo and IP been making many modifications to their fuel/idle maps? / Can this thread be a good one to post config files, discuss changes to improve tuning using this ecu?
(02-22-2018, 06:04 PM)baldur ...
Also, if you are getting smoke at idle there's probably nothing the ECU can do to contain that, that's going to be a mechanical issue of some sort...
(02-22-2018, 06:40 PM)AlanMcR(02-22-2018, 06:04 PM)baldur ...
My thinking too. Smoke at idle is timing, injectors, or compression. None of which are controlled by the ECU.
Another big update. Released firmware version 1.20 today.
The major change is that now it is no longer necessary to modify the glow plug relay to work. I have reverse engineered the serial protocol used to communicate with the Mercedes glow plug relays so the standard relay from the W210 can be used unmodified.
(03-18-2018, 02:23 AM)Mr.Emo Amazing, is there a way you to add a function like "pre heat"? I am putting the 606 in a patrol and would love to wire up a switch that allows me to les the engine run slightly above idle to warm up.
A small update, not significant but useful to those who are using the CAN bus for integration to the car's existing systems. In firmware version 1.21 released last week it is now possible to record the traffic seen on the CAN network via the Calibrator application. This aids with diagnostics and figuring out the CAN protocols employed by the car's network.
Since there are a few of you guys running the DSL1 now, how many have restored Cruise Control? How did you build your harness?
Baldur, a question, can you build-in or add a harness for guys who are less electronically confident? I have replaced connectors before, but when it comes to resistors, solenoids and relays, I am lost and fear that I won't be able to get my car up and running in a weekend to drive to work.
Any other guys have any issues? Any pictures? Where have you located your DSL?
(04-30-2018, 07:05 AM)Doug F Since there are a few of you guys running the DSL1 now, how many have restored Cruise Control? How did you build your harness?
Hello Baldur
I have now done all the wiring and when I connected the box to my laptop to do a Pedal position sensor calibration I get error1
At first I did not connect the secondary signal on pin nr 3 on the ECU because on my pedal that is from 0-2,5V, when I depress the pedal fully I can hear the rack moving but at about 15-20% I hear it clicks in the pump and I get 4 error1 after that no more movements in the pump, the fauls is Throttle sensors diagree
And pedal secondary is on 30% see attached file error 1
If I connect the Pedal position sensor secondary on pin 3 I get 8 error1 and when I depress the pedal it go upp to 15 error1 and there is no sound of movement from the pump at all and the error is
Secondary throttle out of range
Throttle pedal voltage to high
Throttle sensor disagree
The pedal secondary is now on 100% and starts to go down to about 65% after I depress the pedal 40-50 %
see attached file error 2
Is this because I am not using a TPS from a W210 car it is from a W211? The secondary pedal sensor is 0-2,5V not 0-5 V primary is 0-5V
If it is because of the pedal Can a do Changes in the value setings in the ECU so it match my pedal or do I need a pedal from a W210 car with a OM606 engine?
I started the engine yesterday and if I dont connect the secondary signal on pin 3 I can rev the engine a little bit abot the 15 % I wrote erlier if I go over that the pedal gets disconnected and the engine runs on low idle speed.
I have two wastegates requiring separate solenoids. Is it possible to control them with a DSL1 based upon MAP sensor signal and perhaps rpm and TPS?
My pump is mechanical for now, and I run a 722.3, but could upgrade both in the future. My only use for this unit at the moment would be for boost control for compound turbos.
I do not know if the DSL1 will send one or more separately configurable signals to 12v relays to actuate the solenoids.
Thanks,
Karl
(06-17-2018, 04:13 PM)atypicalguy I have two wastegates requiring separate solenoids. Is it possible to control them with a DSL1 based upon MAP sensor signal and perhaps rpm and TPS?
Thanks,
Karl
Thanks,
Karl
(06-18-2018, 06:36 AM)baldur(06-17-2018, 04:13 PM)atypicalguy I have two wastegates requiring separate solenoids. Is it possible to control them with a DSL1 based upon MAP sensor signal and perhaps rpm and TPS?
Thanks,
Karl
It is possible to do this. You have a boost control loop and you also have general purpose PID controls. You would need to fit a separate pressure sensor for the intermediate pressure.
Thanks,
Karl
(06-20-2018, 05:41 PM)atypicalguy(06-18-2018, 06:36 AM)baldur(06-17-2018, 04:13 PM)atypicalguy I have two wastegates requiring separate solenoids. Is it possible to control them with a DSL1 based upon MAP sensor signal and perhaps rpm and TPS?
Thanks,
Karl
So would pin 9 and pin 10 send 12v 3A signals to each of the solenoids directly?
Thanks,
Karl
Oh I see how they work now. Perfect. That should do the trick nicely.
I will download the software and check it out.
Thank You
Firmware 1.22 released.
Most notable change is there are now more programmable outputs, as there is a new board revision that has more outputs.
Another notable change is I have developed a feature that allows better drivability with 7.5 and 8mm pumps. If you have a 7.5 or 8mm pump and are using the DSL1 please contact me if you would like to give the new feature a try as it requires some changes to the tuning to work well.
Cool.
Did you ever manage to work in a torque limiting function by gear? Gear could be sensed with a speed/rpm ratios, or by some sort of gear signal from the ofgear tcu I suppose.
Thanks.
(06-27-2018, 07:58 PM)atypicalguy Cool.
Thanks.
Thanks.
Baldur, do you have a basic tutorial or can reference one for basic tuning for us "low level" tuners attempting to use the DSL1? I don't want to destroy my engine so I need to take baby steps when altering fueling, boost, etc.in the tables? Or should I just send you logs? Maybe you'll just tutor me after reviewing logs until you feel like I can spread my wings?
Hello Baldur
Is it possible to get a rpm signal out from the box with just one puls / RPM?
I am using the original RPM sensor to the box and to my tachometer but the sensor reads 4 pulses/RPM so my tachometer is showing the wrong RPM
I am using the engine in a boat so I am not using any original instruments.
Best regards
Andreas
(07-07-2018, 01:42 AM)XBB240 Hello Baldur
Best regards
Andreas
Best regards
Andreas
Baldur, your post #3 says vnt control is there. could you please elaborate as i'm still in the dark on controlling my GTA2359VK? Per our email exchanges, do I need to convert it to vacuum control until you have a chance to address the electronic controller later?
50harleyrider-
sorry to chime in but I'm well into my 2006 f150 4x4 OM606 swap. Just ordered my DSL1 and I Pm'd you a while back to pick your brain on torque converters. If you get a chance, please shoot me a PM as I know you've already dealt with much of what I'm into now.
Thanks
John
(07-25-2018, 09:36 AM)jav1 50harleyrider-Don't use a diesel torque converter. You'll find out the 606 just doesn't have the grunt to get that truck moving with a low stall like a 6.0 or 7.3 has. Stick with your gas TC. I'm going back to mine after a disastrous waste of time and money on a Hughes Performance diesel one. Baldur noticed it on the first log I sent him. I'm trying a vnt turbo off a 648 for quick spool before the truck goes back on the lift for the oe TC reinstall. Otherwise the E4OD performs great and should give some nice MPG figures with the Quick 4 controller.Please PM me and we'll compare notes.
Thanks
John
Thanks
John
Thanks 50harley...
I sent a PM to Winmutt to get some pictures hosted & posted in the project section but I'm not sure If my PM's are working?? I've sent several to you & others but never get a response. PM me your email if you wouldn't mind... I'd love to compare notes.
On the converter... I can't use mine because it's a 12.75" on the 5.4 3 valve triton- and it won't fit on the OM606 flex plate without interfering with the starter. I'm going with a high stall 11.25" from a 2004 Mercury marauder. I'm told this flywheel is the strongest (internally brazed from the factory) that has 31 splines and a locking clutch (both needed from my 4r75e transmission).
I figured I would ask questions on the forum so that others with the same question can find an answer.
I have the DSL1 installed and running in my Land Cruiser 80 project with the default settings in the v1.22 config file. The target idle speed is 700 or so, but after several minutes of idling (at normal operating temp, verified by coolant temp sensor), the idle will slowly creep up to 2000 RPM and remain steady.
It looks like the integrator gain for the idle control is set to 1, so I would think it shouldn't have any steady-state error. Should I try increasing the I gain or is there another issue? My timing is fairly advanced, so I wonder if the "Approximate fuel needed" map needs to have its values reduced.
(10-19-2018, 02:18 PM)anothernord I figured I would ask questions on the forum so that others with the same question can find an answer.
Hi Baldur. I have a question. Is it possible to run DSL1 parallel with the original ECU to retain Oil Temp and Water Temp in the original tachometer ?
(11-04-2018, 03:40 AM)benzoschaua Hi Baldur. I have a question. Is it possible to run DSL1 parallel with the original ECU to retain Oil Temp and Water Temp in the original tachometer ?
(08-20-2018, 06:49 PM)baldur I did some testing recently and I can report that controlling a VP37 pump off an OM602.982 required only minimal changes to the firmware. This opens up the possibility of controlling a whole lot of engines other than the OM605/OM606.
(11-07-2018, 12:43 PM)SurfRodder(08-20-2018, 06:49 PM)baldur I did some testing recently and I can report that controlling a VP37 pump off an OM602.982 required only minimal changes to the firmware. This opens up the possibility of controlling a whole lot of engines other than the OM605/OM606.
Really interested in this...
Do you think it would be reasonably possible to utilize a VP44 (or similar) on an OM606 with one of your controllers? These are much easier to come by and get rebuilt around here. I am also unsure of what needs to be swapped over to get a VP up and running on a OM.
Was there a 6cyl version of this VP?
The VP44 doesn't have a great reputation for reliability. It was used on the 5.9 cummins from '98 to '03 i think ?? Also used on the opel 2.0 DTI engine.
It is a completely different pump compared to the VP37 or the VE. It is frankenstein combining a radial piston pump like the CAV DPA, and electronic controls, it uses a solenoid to control start and end of injection, similar to unit injector control, but it also has a timing solenoid, a triggerwheel to check the current angle of the camplate etc. And the best part ? The heat sensistive ECU is mounted right on top of the pump itself, a very hot place ! IMO it's a nightmare and not worth the effort to get it working.
In the TDI world it's a common mod to use the hydraulic head and camplate from the VP37 in a VE pump. I don't see why it couldn't work in reverse. And the best part is that you can convert the OM602 VP37 to a 6 cylinder for a 606, just swap the camplate,roller holder and hydraulic head for the 6 cylinder one. Dieselmeken probably know's more about this.
Hi Baldur,
Can your controller work with the newer W463 Accelerator Throttle Position Sensor that's built into the pedal.
or are you limited to the 2 mentioned in your manual
thanks in advance
(11-15-2018, 11:51 AM)CutWeldDrive Hi Baldur,
thanks in advance
thanks in advance
