STD Tuning Engine Om606 oil pressure port
Antonytriolo
03-20-2018, 05:25 PM #1
Evening
Is there a spare port on a om605 turbo diesel that I can use for a oil pressure sensor for my digital dash on my landrover project?
Antonytriolo
Evening
baldur
Fast
511
03-20-2018, 05:55 PM #2
Yes. There's a port on the filter housing that is plugged up. I believe it has a M14x1.5 thread.
Baldur Gislason
baldur
Baldur Gislason
Antonytriolo
03-20-2018, 06:01 PM #3
Thanks baldur
It that the one on the side of the housing above the starter motor?
I think there’s one on the back too that I could feel, I might be wrong as I havnt looked
Antonytriolo
Thanks baldur
baldur
Fast
511
03-20-2018, 06:03 PM #4
Yes, above the starter motor, it's the one bolt there not circled.
[Image: 107463d1353886590-help-om606-oil-filter-...ousing.jpg]
Baldur Gislason
baldur
Baldur Gislason
baldur
Fast
511
03-20-2018, 06:04 PM #5
I can't say for sure whether it's M12 or M14, it's been a while since I checked.
Baldur Gislason
baldur
Baldur Gislason
Antonytriolo
03-21-2018, 02:09 AM #6
Aah yes I did see that just wasn’t sure.
I will take it out as I will need a adapter to convert it 1/8npt thread along with getting a T piece for the water temperature as my digital dash is calibrated to its own sender
Antonytriolo
TIMNZ
04-10-2018, 11:39 PM #7
Have just done this, it is M12 x 1.5 mm,   I used a hex head set screw, drilled and tapped the head with 1/8" NPT drilled 3mm hole, and used 2 sealing washers as thread didn't quite go all the way up to the head.
Cheers
Tim
TIMNZ
Cheers
Tim
