STD Tuning Drivetrain 87 300d vs 95 e300 for high power
Insane190d
03-20-2018, 06:54 PM #1
So what is the better option to swap a super turbo om606 in? I like the newer w124 e300 with the non turbo 606 and figured since it's a 606 it wouldn't be as difficult to swap an om606 turbo engine In but are the rears smaller than the 87? I know the transmission is smaller but I'm doing a manual zf anyway. Should I just go with an 87 to swap? Will everything still line up the same?
Insane190d
benzguy
03-20-2018, 07:24 PM #2
The differential is the same size different ratio 2.87 the 87 is 2.65
benzguy
Insane190d
03-20-2018, 08:28 PM #3
Oh ok so it should hold decent power? Is the ratio going to make much of a difference?
Insane190d
benzguy
03-21-2018, 06:23 PM #4
Depends on what transmission you’re going to use you need to match the gear ratios for example I have a 5 speed from a 190D in my E300 it matches the 2.87 because the transmission lower ratios it has 4.23 first gear but my engine is stock if you’re going for a super turbo you can run lower ratios
benzguy
atypicalguy
04-04-2018, 10:51 AM #5
the 87 diff is 185mm rather than 210. You can get a non-asr diff from a 1990-92 500SL which is the larger one at the same 2.65 ratio as the 87. And get the half shafts and rear driveshaft to go with.
atypicalguy
jonbobshinigin
04-08-2018, 01:22 PM #6
I would pick the nicer car in general all around.
1987 300TDT - 260,000 Miles
jonbobshinigin
