STD Tuning Engine Broken exhaust manifold studs om605
Dieseeelstar
04-02-2018, 01:36 PM #1
Hi!
Im wondering if i can use a m8 helicoil kit and use the 8.3mm drill and use helicoil inserts without a problem im afraid to hit oil/water passage should i be worried when take out 1mm in diameter alloy from the head?
Did any one else use m8 helicoil kit?
Dieseeelstar
Hi!
Tobulus
04-02-2018, 11:40 PM #2
No Problem with that, dont drill any deeper
Tobulus
AlanMcR
mind - blown
400
04-02-2018, 11:45 PM #3
(04-02-2018, 11:40 PM)Tobulus No Problem with that, dont drill any deeper
Yes.  I did the full set after some previous mechanic wrecked some of the threads.  Did the intake manifold threads too.  To be fair, the head is rather soft aluminum.
AlanMcR
