STD Tuning Engine Converting OM606 N/A to OM606 LA. Parts needed?
Flashcool
01-05-2014, 07:13 AM #1
Hello people!
I'm converting my OM606 N/A from my 95 124merc to turbo.
I have got already this 606 turbo parts:
intake manifold
exhaust manifold with turbo
prechambers + nozzles
nozzles will get a rebuild
pistons + rings + rods
oil filter housing
Bearings I will buy new for OM606 LA engine.
I have also got the camshafts from turbo, but i will leave my N/A camschafts.
Do I need anything else?
Flashcool
Hello people!
intake manifold
oil filter housing
benzguy
04-15-2018, 08:56 PM #2
Did you convert your n/a engine to turbo ?
benzguy
AlanMcR
mind - blown
400
04-16-2018, 06:48 PM #3
OM606 turbo engines are not hard to get, why do this?
AlanMcR
NZScott
HX30W 73/44mm
398
04-17-2018, 12:53 AM #4
And apparently the NAs hold up to decent power anyway - (300hp?)
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
benzguy
04-17-2018, 06:26 PM #5
What mods do you need to make to the 606 n/a to raise the power ?
benzguy
NZScott
HX30W 73/44mm
398
04-17-2018, 10:12 PM #6
None depending on the power you want (well a turbo would be a good start Wink )
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
hooblah
04-18-2018, 08:01 AM #7
What is 606 LA?
hooblah
What is 606 LA?
Petar
7.5mm M pump
459
04-18-2018, 10:07 AM #8
L - Ladeluftkühler - Charge air cooler in German
A - Abgasturbolader - Exhaust gas turbocharger
Petar
erx
w202 om606
323
04-18-2018, 11:43 AM #9
If you want to make it to stock turbo specs then no need to change anything for 130kw. 100kw engine will handle 130kw with ease. You may change nozzles and set to 135bar but no need to change prechambers, you will never feel difference.
Ok now I found out it's 4 years old thread at start...
This post was last modified: 04-18-2018, 11:47 AM by erx.
erx
