W124 Om606 STD AWD Daily Driver Project
I want a great and manual Daily Driver (which I can get registered in germany) without much reliability issues and AWD. I want to use the 4matic transfer case and some om603 bits for the AWD part and probably a hx30 for the turbo part. For transmissions, I think it will be either the 716.6 or the ZF5 transmission. I also have clutches and other bits already in my mind, but if anyone knows better ways or has better ideas, you can post them here. I also want to point out that i want a manual car with AWD, which means that I cant really use the standard 4matic automatic transmission. If you also know better and more reliable turbo options, you can post them here, too.
(08-25-2018, 10:01 AM)KeinAnderer I want a great and manual Daily Driver (which I can get registered in germany) without much reliability issues and AWD. I want to use the 4matic transfer case and some om603 bits for the AWD part and probably a hx30 for the turbo part. For transmissions, I think it will be either the 722.6 or the ZF5 transmission. I also have clutches and other bits already in my mind, but if anyone knows better ways or has better ideas, you can post them here. I also want to point out that i want a manual car with AWD, which means that I cant really use the standard 4matic automatic transmission. If you also know better and more reliable turbo options, you can post them here, too.
