STD Tuning Engine OM617A Sodium filled valves as Intake valves
Hellcat94
08-29-2018, 07:05 PM #1
So the turbo model of the Om617, the om617a, comes with sodium filled exhaust valves in the head. The whole purpose as I understand it is that the sodium absorbs the heat and keeps the exhaust valves from burning up. An added bonus is that they are about 15% lighter than their solid stem intake amigos, which lightens up the valve train.
The question/hypothesis i have is, could you use the sodium filled exhaust valves in place of the solid stem intake ones, so then you would be running 10/10 cooler & lighter valves?
The exhaust valves are 23ish dollars each and only about $3 more expensive than the intake valves. I think they are the exact same size with 10mm shaft, but I have no proof on length /head shape yet, i havent been able to compare them.
Does anyone have any thoughts on this or a pair of spare valves to compare for me?
Much appreciated, thank you.
Hellcat94
bullonezero
08-30-2018, 01:14 AM #2
The exhaust valves are of a smaller diameter than the intake
bullonezero
NZScott
HX30W 73/44mm
398
08-30-2018, 04:40 AM #3
There's lot of better mods before you worry about intake valves IMO
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
starynovy
09-05-2018, 02:41 PM #4
Sodium cooling efect will not take place at intake temps.
starynovy
