LF: Tuner for OM612 or OM647
Folks,
doing quite a bit of performance work on a few Sprinters and need a tuner - having a hard time finding the right person in NA...my tuner is taking forever to push out the files so I need somebody else
I need somebody that can work with MPPS files, delete/disable EGR and reprogram the turbo from VNT to WG...down the road I would like to swap the 270cdi engine into an E-series with euro harness and ECU so that will likely need another file with adjusted tuning...
Any reccommendations?
up...
I've got the OM612 upgraded to the CP3 pump with higher pressure...engine's up and running but in limp mode - shuts off as soon as I plug the fuel pressure sensor back in which was expected...I really need a tuner to make some changes to this file so I can push forward with my project...
