STD Tuning Engine Crank case vent tube and cone filter
veg124
09-11-2018, 08:51 AM #1
Is there a sticky or popular thread on various air filters used on the OMxxx? Mine is specifically an OM605 without the MAF.
Feel free to direct me to existing threads. I've searched this forum using all kinds of terms, searched Google/images, etc. and can't seem to find anything definitive.
On my OM617, I deleted the big airbox and stuck on a cheapo oiled cone filter with the oil feed line jammed through a hole in the front of the filter. Pretty ugly but seemed to work ok.
Thanks,
Jon
This post was last modified: 09-26-2018, 09:53 AM by veg124.
1982 240D LHD
1982 300TD LHD
1983 300SD LHD
1986 300SDL LHD
1992 300TD RHD
1998 C250 TD RHD
1982 240d RHD
1998 Sprinter 'Prambulance' RHD
veg124
Thanks,
Jon
1982 240D LHD
1982 300TD LHD
1983 300SD LHD
1986 300SDL LHD
1992 300TD RHD
1998 C250 TD RHD
1982 240d RHD
STDGer
09-27-2018, 01:46 AM #2
Hi Jon,
i m running a 605 in 202 c class with oem airfilterhousing. I did some mods to increase the flow.
If u have the c klass filterhousing, thers a modeled pipe behind the headlight. Cut it off to get a big intake hole.
also get the rubber under ur headlight aperture away to get more fresh air behind ur headlight.
ex 04. 1997 w202 om605 sedan ,Dieselmeken 7.5mm, 3" exhaust, he351w, 716.657 ca 350+ hp
actual 08. 1997 w202 om605 station wagon, oem edc pump, modded exhaust manifold, t04e turbo, oem pipe 1 silencer wannabe as much as possible
STDGer
Hi Jon,
veg124
09-29-2018, 03:56 AM #3
(09-27-2018, 01:46 AM)I STDGer Hi Jon,
How does it sound? I’m a sucker for that turbo whine :-) even though it probably has no bearing on power.
Thank you for the suggestions! I’ll have a look today and try to see what you’re describing.
I’ll also PM you about your setup w the T04e.
Vielendank,
Johanness
1982 240D LHD
1982 300TD LHD
1983 300SD LHD
1986 300SDL LHD
1992 300TD RHD
1998 C250 TD RHD
1982 240d RHD
veg124
Vielendank,
Johanness
1982 240D LHD
1982 300TD LHD
1983 300SD LHD
1986 300SDL LHD
1992 300TD RHD
1998 C250 TD RHD
1982 240d RHD
veg124
09-30-2018, 09:55 AM #4
This ‘Filtereinsatz’? Cut a hole here?
And the second picture, cut this as well?
[Image: 5E1A4679-7B7B-4900-9735-5D47BBFA29B1_zpsj8o4nljd.jpg]
[Image: 2A40254B-A577-4E5C-8E87-6454CB66EE21_zpsgf8ahkj2.jpg]
1982 240D LHD
1982 300TD LHD
1983 300SD LHD
1986 300SDL LHD
1992 300TD RHD
1998 C250 TD RHD
1982 240d RHD
veg124
1982 240D LHD
1982 300TD LHD
1983 300SD LHD
1986 300SDL LHD
1992 300TD RHD
1998 C250 TD RHD
1982 240d RHD
