STD Tuning Engine OM605 T04E Remapped EDC
Jberryman
11-24-2018, 09:38 PM #1
Hi all,
I have a w202 c250td with a ebay T04e turbo & sean tracy stage 2 ecu remap and straight through exhaust
Had it on the dyno and it only made 146hp at the rear wheels and the air fuel ratio was extremely lean
It feels extremely asthmatic and does not blow any smoke at all.
I have ordered a new lift pump & injector pump timing tool to check the timing
Have also replaced the fuel filter.
Unplugging the MAP sensor makes the car barely drive, so I think it is still okay
Any advice will be much appreciated
Jberryman
Hi all,
seanyt
is300d He351ve
279
11-25-2018, 05:58 AM #2
Measure voltage at the map sensor under full boost.
It's making more power than stock.
But something is not right.
Try a new map sensor or fit an electric pump to the fuel feed.
Remove any airfilter and test also
seanyt
Jberryman
11-25-2018, 07:49 PM #3
(11-25-2018, 05:58 AM)seanyt Measure voltage at the map sensor under full boost.
Thanks Sean, what voltage should it be showing?
Are aftermarket MAP sensors okay? Genuine is like $180usd even with my discount
Jberryman
seanyt
is300d He351ve
279
11-26-2018, 09:21 AM #4
You done need genuine.
part number: 011 542 07 17
You want to see upto 4.4v for 1.65-1.7 bar boost.
seanyt
