STD Tuning Engine C30 CDI AMG Nozzle Part Number?
Drewkeen
01-07-2019, 11:38 PM #1
I have been searching hard to find this with no luck. I am looking to buy a set and this car was never sold in my country so the dealer cannot get the Bosch part number either.
If anyone has it please pass the info along for me and others. Also any feedback you may have if you run them would be greatly apprecaited!
Drewkeen
AlanMcR
mind - blown
400
01-09-2019, 12:53 PM #2
This ought to help:
https://mercedes.7zap.com/en/eu/fg/car/c...0/105/0/0/
Turbo
01-09-2019, 05:10 PM #3
May I ask why you need it?
Turbo
Drewkeen
01-09-2019, 07:38 PM #4
Thanks, looks like the part number is A 612 070 02 87 for anyone looking for the C30 CDI AMG Nozzle part number.
I am trying to increase to power of my car. I am looking to install a larger turbo, 400 CDI High pressure pump, intercooler, tune and some larger injectors.
I have been debating what to do and wanted this part number to price these nozzles and see if they are available in the US. I am always open to suggestion and help from anyone that has upgraded one of these engines.
Thanks!
Drewkeen
Thanks!
Turbo
01-13-2019, 09:22 AM #5
what does Nozzle cost?
re-manufactured 0445110152 injectors on ebay you can find for 90£.
How much power do you want?
There is way bigger and better injectors then 0445110152/3 but they need much higher pressures.
if you want be in another ball park get the H vertion of the CP3 110 pump for higher injection pressure, but 0445110152/3 is not for high pressure
This post was last modified: 01-13-2019, 09:34 AM by Turbo.
Turbo
Drewkeen
01-18-2019, 01:05 PM #6
(01-13-2019, 09:22 AM)Turbo what does Nozzle cost?
The problem is finding someone that is willing to ship those injectors over the me in the US. After doing a bit more reading those injectors do not seem optimal for the higher injector pressures of the OM648 engines and are probably just a cheap way to make a bit more power, but not the optimal way to make more power and have a very clean injection event.
What engine was the H version of the CP3 100 pump on? Did the OM628 and OM629 both get this pump? Do you happen to know the full part number for it, I have also been searching for one of these to go along with a larger turbo and injectors.
Drewkeen
Turbo
01-21-2019, 04:04 PM #7
pm me and we can discuss it further
Turbo
01-24-2019, 09:08 AM #8
Hum ...
Cp3 L110 came on 612 D30 and 628. 0445010029.
Anyway 7 hole AMG injector is the best injector of the stock ones... after those only custom made.
Nozle holder use A6120700287.
This set is 170cc 180cc.@1000ms.
Good luck
Hum ...
Good luck
 6 Guest(s)
 6 Guest(s)
