STD Tuning Drivetrain Which 722.6 for 94 e300d (N/A om606)
Mh95e300d
01-07-2019, 12:54 PM #1
Hello guys.
(I tried searching & searching)
So my stock transmission(722.4) in my 94 e300d (N/A om606 engine) is showing signs of failure(not able to move in reverse if it has to climb/ move on slope).
Now in near future I might be doing some performance upgrade to this car(internal, turbo, pump upgrades and plans to achieve somewhere 600hp) but for now stock car
So I was wondering instead of getting this transmission rebuild, why not start searching for all the required parts including the 722.6 transmission and swap it.
Now I am not too much of technical guy in this department and my trusted mechanic would do the swap. So required least tricky fit, list. Now can anyone suggest (other than olefejer's standalone controller,tps sensor)
Out of which vehicle should I be looking for 722.6, bellhousing, instrument cluster etc for my vehicle and and current need.
Maybe a complete list from someone who has already done same to same spec car, would be of great help.
Looking forward to your valuable suggestions.
Thanks
Mh95e300d
Hello guys.
Thanks
Mh95e300d
01-08-2019, 11:34 PM #2
I am narrowing down to e270cdi gearbox. Will it be good enough for 700-800nm for my future upgrades?
Mh95e300d
Mh95e300d
01-26-2019, 09:02 AM #3
hey guys so its sorted
olefejer controller
e270 cdi gearbox (easily available, no bellhousing swap, might add clutch if I upgrade figures in future).
w202 gearshifter
yet to figure out
TPS
CLUSTER.
any suggestions and link to it?
thanks
This post was last modified: 01-26-2019, 09:03 AM by Mh95e300d.
Mh95e300d
olefejer controller
w202 gearshifter
yet to figure out
TPS
CLUSTER.
thanks
Petar
7.5mm M pump
459
01-27-2019, 08:31 AM #4
Possible solutions for tps:
https://www.youtube.com/watch?v=Zk20Sa-JY3E
https://www.youtube.com/watch?v=UW1bfOLegGk
For speedometer you can use W124 V8 cluster or W126 speedometer and mod it so it fits the W124 cluster
Petar
Mh95e300d
02-11-2019, 01:38 PM #5
Great thanks.
Now on my last part of puzzle. I am planning to add clutch packs before gearbox swap as "do it once" thing, as I will soon be high power building the car. Now I am novice to this thing and e320cdi and v8 boxes from w211 are my super rare in my country and e270 box is readily available. Any leads on that guys
Mh95e300d
Great thanks.
Mh95e300d
02-23-2019, 09:09 AM #6
Just when I was about to bite the bullet for e270 gearbox, I got to know a 722.636 gearbox is up for sale.
Now my query is, that the bellhousing from 722.4 gearbox in my w124 e300d mated to om606 n/a originally, can be used for swapping the bellhousing of 722.636 to make it fit to om606
This post was last modified: 02-23-2019, 09:11 AM by Mh95e300d.
Mh95e300d
Petar
7.5mm M pump
459
02-24-2019, 03:25 PM #7
No, as the 722.4 is one piece, without a removable bellhousing. Of course you could cut and weld but it's a lot of work
Petar
Mh95e300d
03-06-2019, 01:18 PM #8
(02-24-2019, 03:25 PM)Petar No, as the 722.4 is one piece, without a removable bellhousing. Of course you could cut and weld but it's a lot of work
thanks.
guess now have to look for e270 bell housing along with e55 gearbox
Mh95e300d
thanks.
erx
w202 om606
323
03-06-2019, 01:41 PM #9
(03-06-2019, 01:18 PM)Mh95e300d
thanks.
Any bellhousing from petrol or diesel 1.8-3.0 straight engine will fit, only 3.2cdi and V8 is different.
erx
thanks.
Hellcat94
03-07-2019, 09:11 PM #10
Hey there, dont want to hijack the thread, but does anybody know the gear ratios on a 722.629 transmission? Also if anybody needs an inline bell housing for one, I will trade for a round style one.
Vom Vom Vom
Hellcat94
Vom Vom Vom
 7 Guest(s)
 7 Guest(s)
