602 flywheel
602 flywheel
I'm going to do a conversion auto to manual and I need the flywheel there is one in EBay Germany that I like to buy but I asked the seller what clutch size does it takes and he does not know he only knows the part number which is 6020301305 does anybody on this forum knows my engine is 602 turbo so I need a 9 inch clutch or bigger I have a flywheel from a 601 but it takes an 8 inch disc
Not sure on that part number. I found a reference to a g-wagon with the 602/m102 motors and they used a 228mm (9") clutch so that one may be right. If the seller could take a pic of the other side it should be fairly obvious.
Have you considered one from 16v 190e? Thats what I used in my car. Looks like captruff (Jeff) has one on eBay right now. I got mine for $100 off car-part.com and just had to get it resurfaced. There is one listed now over at M&M there in Fontana but no price listed.
http://www.ebay.com/itm/Mercedes-190E-2-...2H&vxp=mtr
I don't know in the 60x case but with OM616/OM617+M110 the G wagens had different flywheels with larger clutches than the sedan version, and I bet the T1 vans were the same, so if you want a flywheel with a larger clutch avoid a sedan one
is there such a thing as an upgraded pressure plate for the 8" clutch?
(10-24-2018, 06:32 PM)benzguy Yes there is an upgraded pressure plate I remember reading about it on the 190rev website
