STD Tuning Engine om605 vacuum hiss?
om605 vacuum hiss?
om605 vacuum hiss?
veg124
04-04-2019, 05:09 AM #1
Hello,
I am still learning about the new to me om605 powered W202 C250. I'm curious what is causing a back up of vacuum pressure, that's the only way I can describe it. When I turn off the engine, it slowly releases but I can totally release it if I pull a vacuum line.
Hopefully the link to this short video of it will post here. Not 100% sure about the forum rules linking to YouTube.
I am not sure how this has, or whether it has been, affecting performance. I have blocked the EGR line with a 5.5mm metal bit but otherwise the setup is stock AFAIK.
Thanks,
Jon
1982 240D LHD
1982 300TD LHD
1983 300SD LHD
1986 300SDL LHD
1992 300TD RHD
1998 C250 TD RHD
1982 240d RHD
1998 Sprinter 'Prambulance' RHD
veg124
Hello,
Thanks,
Jon
1982 240D LHD
1982 300TD LHD
1983 300SD LHD
1986 300SDL LHD
1992 300TD RHD
1998 C250 TD RHD
1982 240d RHD
dieseltorque
04-05-2019, 12:26 PM #2
Hi,, I had same noise when my c250 was stock,, it comes from turbo actuator control valve. Car was running fine without any issues.
dieseltorque
AlanMcR
mind - blown
400
04-05-2019, 06:04 PM #3
"They all do that"
It is the noise of the vacuum slowly bleeding out through the variable vacuum valve(s). There is one for the turbo and another for the EGR. Be happy you hear this sound. If you don't, it means that you have a larger leak somewhere else.
Now, about the bird noises that I heard ...
AlanMcR
"They all do that"
