OM 606 Turbo, complete rebuild and mechanical Pump
Hi guys,
Here are my OM606 with self builded Pump (own testbench), the Pump is set on my own settings with big Elements (-;
Not from Göran or Luke
But, have a look:
https://youtu.be/cNM_t2AVQdI
Best reguards Steffen
The HP is setted on 177HP and tourge on 330Nm, or a bit more
the engine is running to 3500rpm, not more, the G-Wagon just run 123km/h.
Sounds and looks good. What size elements? Could we get more info on your build? Will it be intercooled in the truck?
Hi,
Yes I have some Pictures from the oil Nozzles here in this forum, for the complete build here is a link to the German Forum:
https://www.multi-board.com/board/index..../&pageNo=1
The Pump work with 9mm elements, I don’t want to mount an intercooler on, because I think I don’t need it and I don’t have space.
The injection nozzle inlets, are also special parts, not Bosch or what else.
I don’t have done a „kick down“ ( I don’t know the English word) I‘ve go slowly to 3500 rpm.
What the 606 made at full fast load, I don’t know, I was scared (-;
https://youtu.be/ii0ZuhKr3bk
When you have questions, please ask
Hi Guys,
here my 606, which take place in my car today.
https://youtu.be/cqYIvhpVDb0
https://youtu.be/5fYCLYSx2hA
https://youtu.be/y6U3ympXVlk
best reguards from Germany, Steffen
(12-15-2019, 04:42 AM)German Diesel Hi,Wow 9mm elements. That's huge, where did you get those ? I didn't even know so big elements existed for these pumps. What cm3/1000 strokes have you set your pump at (if it's not a secret
Hi,
Thanks, the engine runns very well (-; The 9mm elements are developed by myself, to get the best performance.
What amount of Diesel i put i is a secret, yes, but i still say, it is not so much (-;
The best performance you get, when you set up your pump as a unique product. Not so much black smoke, with big power.
I tested the 606 on a lownly road, the speeding up to 100km/h was faster then the E300TD W210 serie with 1000kg less. All components are basic.
And the Pump is a soft setup.
The use of Diesel for 100km are 7 liters at the moment, my aim is 6 liters.
best reguards Steffen
Hi,
The next engine is going into parts (-;
https://up.picr.de/39368817su.jpg
https://up.picr.de/39330219yu.jpeg
https://up.picr.de/39371280hp.jpeg
https://up.picr.de/39370763gy.jpeg
https://up.picr.de/39370762vx.jpeg
Hi, but you work on it ?
For the Cylinder bore. 2/100mm bigger then 87,000. so like new
The bigger one has an other mark, so it’s also new
Next week, before the 606 goes to one engine, a OM603.972 with a 22er head goes into parts.
From this engine I need the Oilpan and Oilpump.
Pictures are coming soon
Some for the overview:
This engine gets a super Pump like my ones, but with more HP
This pump I also build on my own Testbench
Best regards
Hey Guys,
Now the OM606 is running, and much faster then before (-;
https://youtu.be/jJvytElw8TE
https://youtu.be/Bc7VTatXWUE
The Injektionpump is also build from me on my Testbench.
The OM606 from the post from 09.09.20 is also assembled, but it isnt a 3,0 liter, it is a 3,5Liter OM606 (-;
This Engine gets lots of Power, with a very special injectionpump Setup (-;
best reguards
