STD Tuning Engine EDC Pump to chassis multipin
Photomonkey
11-23-2021, 09:42 PM #1
Of all my questionable posts, I am by far most embarrassed by this one...
How do I remove/reconnect this connector?  The end of the EDC pump to w210 chassis connector.
I can't remember if there's a trick to it; it's been long enough that I can't remember; I don't want to break it... yada yada yada
Thanks!
Photomonkey
Thanks!
11-24-2021, 04:18 AM #2
Just plug it in... in the right position, the slide lock may have to be forced or slide open to lock.
Remove by sliding the lock open.
Its questionable , but as everithing in life one need to learn...
AlanMcR
mind - blown
400
11-30-2021, 12:48 AM #3
As barrote said. The latch can be seen to be free when the slide lock is pushed inwards. Though it can take a pretty firm push/pull to get it together or apart.
AlanMcR
