STD Tuning Engine Mercedes 605.910
Mercedes 605.910
Mercedes 605.910
benzguy
12-05-2021, 03:37 PM #1
i would like to know if a injection pump from a 602.910 n/a will fit and work in a 605.910 ?
benzguy
12-06-2021, 04:57 AM #2
Yes it will,
Nevertheless some parts inside are diff.
Fueling for instance...
May i ask why such change?
Regards
Yes it will,
Regards
benzguy
12-07-2021, 03:26 AM #3
I’m buying a 605.910 to be swap for the 601 in my 85 190D in America we never got the 605 and to make the 605 work in the 190 I need the mechanical pump I just like to find out if it’s going to have the same power or maybe less
benzguy
12-07-2021, 03:36 PM #4
Hum hum ...
U havd to buy a 605.96X
Then a min 6 mil pump got to be prepared, from that one u have so u can hit 150hp or a litle more.
If u wich PM me i help u through the process.
Regards
Hum hum ...
Regards
benzguy
12-07-2021, 06:34 PM #5
The 605.96x it’s harder to find and not every one is willing to ship it to America so I already bought the 605.910 from Spain I know it’s going to be a better engine then the 601 and I converting to manual transmission 5 speed I still looking for the flywheel
benzguy
Petar
7.5mm M pump
459
12-08-2021, 03:09 PM #6
It will work and run fine, but without adjustment it will only make 602 power (~95hp)
You can adjust the full load screw to get the extra 20hp or so.
Petar
12-08-2021, 04:04 PM #7
Well, as Petar said... no turbo no fun, no fuel no pnys...
BTW buying a 605.911 in spain is quite a bad idea, when u could had had one 605.96X from UK at half price.
Next time ask around i'm sure many will be glad send u an engine...
Wish u luck with the build.
benzguy
12-09-2021, 03:34 AM #8
(12-08-2021, 04:04 PM)barrote Well, as Petar said... no turbo no fun, no fuel no pnys...
Well I’m asking now because they canceled my order they gave me a good deal 575€ for the engine and 675€ for shipping  I think they made a mistake. I’m looking now for the 605.96X I’ll appreciate the help
benzguy
12-09-2021, 05:05 AM #9
No they did not. Its just besides there are also few of those engines around nobody wants them. Its not its a bad engine, its just isn't as though as a .96X therefore does not hold abuse very well. Just rodwise. Pistowise too. Head assy is also slightly diff. For a STD need some upgrade...
In UK is the place to look.
Regards.
Regards.
benzguy
12-09-2021, 10:18 PM #10
Thanks a lot for your help Francisco. And Petar thanks for the tip if I ever get my hands on a 605.910 I’ll do that
benzguy
 6 Guest(s)
 6 Guest(s)
