Wolverine Oil Pan Heaters Vs Engine block heaters?
i found this site as i was looking for engine block heaters for my car
http://www.wolverineheater.com/
they look good and say its better then the block heaters?
anyone have any input?
Oil pan heaters do nothing to warm the engine itself or the combustion chambers.
There is nothing wrong with an oil pan heater, why heat the block and have cold oil?
I have a MB block heater, and also have a magnetic oil pan heater. I don`t need it here on the Monterey bay area, but when Iam in some cold freezing part of the country, I use them.
warm oil will flow into the vital parts of the engine a lot easier than cold oil. I can only emagine what the effects the cold has on an engine, like now with the weather in the minus double digits back east w/o some type of engine heater.
Charlie
(01-10-2010, 12:00 PM)charmalu There is nothing wrong with an oil pan heater, why heat the block and have cold oil?W116Lorinser is asking about using an oil pan heater instead of a block heater.
(01-25-2010, 06:02 AM)Gurkha How bout flow dynamics, thicker oil won't reach the critical parts sooner enough or not reach at all in worse case scenario.
Also with warmer oil the engine cranks over faster helping it make more compression and start much sooner! If they crank over to slowly in cold weather it may not start at all!
