STD Tuning Engine Exhaust for Project EM9D
Rudolf_Diesel
Ask me if I care...
03-15-2010, 08:32 PM #1
I am going to have my exhaust redone from the flex pipe to the tail pipe, considering the current project I am taking suggestions from the group as to what you would you run if it were yours. Keep in mind I want to run a muffler to keep the drone down.
I have 4" exhaust on my truck, straight through (here kitty kitty)Big Grin and it drones on the freeway, but I love the sound of the turbo cause it sing sing sings.
Your help is appreciated...
Rudolf_Diesel
03-15-2010, 08:46 PM #2
The stock resonator and muffler are a straight through design, I'd just cut off the center resonator or back muffler. Aftermarket mufflers wouldn't be any better unless you go with a 3" system.
http://www.superturbodiesel.com/std/stra...t-625.html
This post was last modified: 03-15-2010, 08:48 PM by ForcedInduction.
Rudolf_Diesel
Ask me if I care...
03-15-2010, 08:50 PM #3
(03-15-2010, 08:46 PM)ForcedInduction The stock resonator and muffler are a straight through design, I'd just cut off the center resonator or back muffler. Aftermarket mufflers wouldn't be any better unless you go with a 3" system.
My original exhaust had the kidneys, which I removed and I added a straight through pipe to the OEM muffler.
I kind of wanted to complete the "performance" package to this project...
Rudolf_Diesel
E300TSC
Turbo-Supercharged
321
03-16-2010, 05:17 AM #4
300HP is 300HP whether it's the 7.3 or the 3.0, it's processing about the same amount of air. I'd go a minimum of 3" since it's not working as hard as the truck engine.
I think I'm going 4" with an Aeroturbine muffler designed for Diesels but the jury's still out on that...
E300TSC
03-16-2010, 08:57 AM #5
(03-16-2010, 05:17 AM)E300TSC 300HP is 300HP whether it's the 7.3 or the 3.0
But the torque and RPM at that 300hp is very different.
03-16-2010, 01:42 PM #6
good point! go 5 inch and dump it out of the side fender like an SLR McLaren
This post was last modified: 03-16-2010, 01:44 PM by willbhere4u.
Kozuka
I'm_Badass
334
03-16-2010, 01:59 PM #7
I have a question.. Whats the exhaust output flange size on your turbocharger? Why don't you just use that all the way back for the least restriction?
Like since I am using a 300TD W124 Down Pipe, for my stock engine install (I have a long list before Twin-Charger comes up haha.). I'm going to just use the 2.5" ( I think thats what it is ) all the way back. I don't think there would be any decrease in back pressure if your going from a 2.5" down pipe to a 4" particulate filter-back. But It wouldn't be nice to go from a 4" down pipe to a 2.5" exhaust.
Kozuka
E300TSC
Turbo-Supercharged
321
03-16-2010, 05:56 PM #8
(03-16-2010, 08:57 AM)ForcedInduction
True dat!
E300TSC
True dat!
CID Vicious
03-17-2010, 03:19 PM #9
I'd have an exhaust shop fab up a straight system, no muffler, from the turbo to the back of the car. If you decide you want a muffler, carefully cut the back pipe and you can have an interchangeable system, though a 3" straight through muffler wouldn't be much more restriction, and with a twin-charged 617a...well I'm assuming cutting a few bucks out isn't top of the list. I do agree, though, if you're not doing the downpipe, just remove the resonator. 4" would be stupid, a 300hp PS is making, what, 600lb ft? If not more? That's a better indicator of the airflow, meanwhile a 617a would be more like 450lb ft at 300hp. Aside from how the hell you're going to get a 4" system under a unibody car that never had a performance variant from the factory...
Besides, 3", a shop's like ok, that's a bit more...4", leave your wallet and come back in a while.
CID Vicious
