How do you bleed an IP?
Hi guys.
Need to bleed out a fuel system on a 300SD to get old fuel and crap out of it. It's been sitting near 10 years. Got new fuel filters on it and several spares of each. New ones are on and filled.... Just need a little info. Thanks!
Drain the tank, put 3 gallons of fresh fuel in the tank, pump the primer about 50 times, drain the tank again and fill it with fresh fuel.
