Unhappy factory rebuild
picked up this gearbox a few months ago with the intention of putting it in my 85 wagon eventually, and finally took it apart. It was extremely corroded on the outside, but seemed to work. Also had a MB sticker and appears to have been a relatively recently rebuild, however horrible looking.
I pulled the drain plug and found this- always a good sign
What happened is the 3rd gear brass clutch spring mechanism some how got out from the clutch/synchro, flew out into the rest of the transmission, and ultimately destroyed both front bearings. Related, but perhaps before this failure, the 3-4 shift collar teeth are all worn down for both gears, and part of the detent mechanism is damaged.
All the other bearings are good, and all the brass clutches are in perfect new looking shape except for 3rd gear, which is scuffed a little.
some pics of the damaged components-
What I am trying to determine is HOW this failure occurred, so when I replace or repair all the damaged components, it does not happen again. I keep coming back to this really confusing bit of the transmission that has me stumped.
Inside the input shaft, there is a spring, several unusual bearings, washers and spacers. They appeared to be sort of thrown in there when I took this apart and I feel like they have to be related somehow to the failure, but I can't figure out what the purpose of this spring is. I have not seen this before, and there is no load on it, or any thing about the output shaft that could be spring loaded.
some pics-
Anyone have any theories?
I've never seen that before
I've seen a spring and a large ball bearing in there? in some Toyota trans
waiting on classic center exploded views, but some of the hard gear parts may be NLA from what I have been hearing, which would be annoying.
In that case, I might have to put a bead of weld on EACH of the worn out nubs, file it down to the right shape, then figure out how to harden it, if such a scheme is even possible.
No wiser on what the purpose of this spring is either, took it by a buddy of mine that does a lot of transmission work, his response was "WTF is as this?"
it's probably something someone rigged in there to get it going... something got lost and/or broken and that's what the "solution" ended up being...
(07-20-2010, 10:29 PM)SurfRodder it's probably something someone rigged in there to get it going... something got lost and/or broken and that's what the "solution" ended up being...
Yikes those are some nasty views. Hopefully there is enough usable parts to salvage off of that trans.
(08-11-2010, 07:17 PM)DeliveryValve Yikes those are some nasty views. Hopefully there is enough usable parts to salvage off of that trans.
