Replacement or Custom ALDA
My Alda has been off for a while now because it obviously was not working well. I removed it and there was a huge difference. But also a little more smoke at idle, and lots of smoke when past 1/2 acceleration. Where can I get a new one, a custom one, or can this one be repaired? I read the write-up a while back about a guy who rebuilt his but is seemed indefinite.
Build one yourself. Basically remove stock and install one that limits shutdown-lever travel upwards. Boost raises a cylinder/actuator which now lets the lever go further up, and all the way up on full boost. If one doesn't want to modify the linkage inside the pump, the limiting device has to be made so that it won't restrict the lever going downwards. Otherwise the engine can't be shut down.
I built this kind of thing in my current pump over a year ago (not seen in the picture: there are now two additional springs to modify the cracking and full fueling pressures the way I want them to be)
For the next pump I'll do it without modifying the internals, replace the actuator with a cylinder, put a separate spring with easy preload adjustment etc.
(07-26-2010, 12:00 PM)muuris Build one yourself. Basically remove stock and install one that limits shutdown-lever travel upwards. Boost raises a cylinder/actuator which now lets the lever go further up, and all the way up on full boost. If one doesn't want to modify the linkage inside the pump, the limiting device has to be made so that it won't restrict the lever going downwards. Otherwise the engine can't be shut down.
