STD Tuning Engine Installing pyrometer?
Actros617
What's a spark plug???
49
07-30-2010, 01:44 PM #1
I have seen people drilling their exhaust manifold with the engine running and a shop vac running right beside the drill bit and to tap it they use a vacuum and used grease on the tap is this method safe for the turbo??
1984 300SD 4 Dr Diesel Sports Car (ARGUS) (Mine)
1987 300SDL Cruiser STOCK (My fathers)
Actros617
07-30-2010, 06:49 PM #2
Its very dangerous for the turbo. Do it right and remove the manifold.
Actros617
49
07-30-2010, 08:20 PM #3
(07-30-2010, 06:49 PM)ForcedInduction Its very dangerous for the turbo. Do it right and remove the manifold.
How about removing the 12 bolts that holds the middle part and the intake of the turbo, i just dont have the space to remove the entire exhaust sysrtem and intake manifold
Actros617
DrewGerhan
101
07-30-2010, 08:26 PM #4
It really wasn't that bad when I did mine. Took a few hours after a day or work. I personally didn't want to risk it. Plus I feel it is in a better position under the manifold, less clutter up top.
DrewGerhan
07-31-2010, 07:49 AM #5
Plus less heat put into the probe and wiring.
