STD Tuning Suspension lowering a 300sd
lowering a 300sd
lowering a 300sd
Ellerd123
08-08-2010, 11:23 PM #1
ok i need some help, where can i get lowering springs for a 1984 300SD?
and will lowering springs for any other make mercedes work, id like to drop it 1.5 to 2 inchs
Ellerd123
benzlikewhoa
08-09-2010, 06:54 PM #2
cut 3 coils front 1.5 rear it will still ride like butter
benzlikewhoa
Ellerd123
08-09-2010, 10:06 PM #3
(08-09-2010, 06:54 PM)benzlikewhoa cut 3 coils front 1.5 rear it will still ride like butter
ok, i realy was hoping to avoid cutting the springs in case i wanted to put it back stock hieght some time, but if i cant find anyother way then ill do that thanks
Ellerd123
08-10-2010, 08:15 AM #4
Different thickness pads are available as well as springs from other models.
Ellerd123
08-11-2010, 03:32 PM #5
(08-10-2010, 08:15 AM)ForcedInduction Different thickness pads are available as well as springs from other models.
what all other models could i use springs and pads off of? cause theres some in a junk yard near where i live
Ellerd123
