STD Other Non MBZ Diesel Best 4 cyl for horsepower?
erling66
SuperDieselVan
294
09-12-2010, 05:17 AM #1
Hi I have only room for a 4 cylinder engine in my car, so what will be the best turbo diesel engine? I mean most reliable and horsepower potential?
Maybe Toyota 3.0td or Isuzu 3.1td with mechanical diesel pump?
Thanks
erling66
Thanks
09-12-2010, 09:51 AM #2
The 2.2L CDI is a very good option if you aren't put off by computers.
The Detroit Diesel Series 50 is another good option. 8.5L, 1,150ft/lb torque and 320hp of fun! Big Grin
[Image: P7170001.JPG]
erling66
SuperDieselVan
294
09-12-2010, 02:01 PM #3
Thanks for nice photo of a great engine but I think it will be a little heavy in my Toyota van.
Well I am old school so I like diesels that can run without electricity. Any other suggestions?
erling66
Biohazard
Smokin like a champ!
376
09-12-2010, 04:37 PM #4
(09-12-2010, 02:01 PM)erling66 Well I am old school so I like diesels that can run without electricity. Any other suggestions?
Dang, that eliminates the VM 2.8 from the Jeep Liberty that was going to be my vote.
Biohazard
Jtn190D
MERCEDES DIESEL POWER!
192
09-12-2010, 05:02 PM #5
I would think over there you guys should have plenty of small diesel's?
Jtn190D
09-12-2010, 07:41 PM #6
1.6 VW and 2.4L MB are the only small mechanical engines we got in significant numbers. There were a few Toyota/Nissan/Mazda/Isuzu engines, but they're rare.
This post was last modified: 09-12-2010, 07:42 PM by ForcedInduction.
09-12-2010, 08:06 PM #7
Evan Toyota never imported diesel over here to the US we only get 2nd hand imported ones from other country's
This post was last modified: 09-12-2010, 08:06 PM by willbhere4u.
09-12-2010, 08:15 PM #8
(09-12-2010, 08:06 PM)willbhere4u Evan Toyota never imported diesel over here to the US
Sure they did. I just saw one in Idaho Springs at the Phoenix Gold Mine.
erling66
SuperDieselVan
294
09-13-2010, 04:03 AM #9
First reply to Biohazard: I heard that all the VM(Italian) diesel engines in Jeep/Plymouth are junk?
Well here in Europe we have a lot of Diesel engines in the junkyards, but it is very unusual to tune them for more horsepower(only some Finish guys that no one understands)
Maybe it is a good idea to fill up a container with good used engines and bring them to USA?Smile and put in some manual transmissions ad well.
erling66
09-13-2010, 04:26 PM #10
Its an import I have worked on them at the Toyota shop in Berthoud Co the dealers never sold them here! But people brought them in from Canada
You have to get the parts sent over from Japan through the dealer it's a nightmare because the US dealers know anything about them and usually order the wrong parts!
meanwhile you don't find out till months later when they arrive! Took us almost a year to get all of the parts to rebuild a 2L 4cyl non turbo diesel
That's the Toyota 2L diesel in your pic forced but ours had a turbo kit made for it hence the engine rebuild it melted the pistons!
This post was last modified: 09-13-2010, 04:28 PM by willbhere4u.
Biohazard
376
09-13-2010, 08:03 PM #11
The biggest thing I've heard on the VM 2.8 CRD is the intakes plugging up with carbon from the egr or pcv system. But, the VW TDI was also pretty well known for that also. It's a bit of labor, but not too expensive in parts (at least the VW wasn't) to pull the intake & egr and clean them; I want to say it used to be about 40 bucks in parts and about 500-600 in labor! My brother used to have the Liberty with the 2.8 CRD, it was a blast to drive. It had tons of torque for how small it was! The engine is all aluminum, too... Smile
Biohazard
09-14-2010, 05:12 AM #12
Many say the VM engine really benefits from a lower stall TC to take advantage of the engine's natural low RPM torque.
erling66
SuperDieselVan
294
09-14-2010, 03:30 PM #13
Maybe I should try to make room for a 6 cyl Mercedes. Take a look at this video
http://www.youtube.com/watch?v=24afjVqm2...r_embedded
erling66
appie
09-30-2010, 03:02 PM #14
How about a 5 banger? With the radiator mounted on the side,like the old audi's.
appie
MikeJRA
11-18-2010, 12:53 PM #15
I just noticed how old this thread is but thought I should add, the VW 1.9 TD is great engine once you fix the crank nose, a known issue. There are some that have also put mechanical pumps on early 1.9 TDI's.
This post was last modified: 11-18-2010, 03:56 PM by MikeJRA.
Bike Mike
MikeJRA
Bike Mike
ben2go
Diesel Dumby
129
11-18-2010, 10:04 PM #16
(11-18-2010, 12:53 PM)MikeJRA I just noticed how old this thread is but thought I should add, the VW 1.9 TD is great engine once you fix the crank nose, a known issue. There are some that have also put mechanical pumps on early 1.9 TDI's.
Yep.I really dig the 1.9TD.What's the issue with the crank snout?I'm thinking of dropping one in my Tracer Wagon.
There's a guy on www.boatdesign.net that converted a couple 1.9TDIs to marine engines.He didn't use many marine parts either.He DIY'ed on the cheap. http://www.boatdesign.net/forums/diy-mar...19118.html
ben2go
MikeJRA
11-19-2010, 12:20 AM #17
That boat conversion looks cool.
The issue is with the AAZ 1.9TD crank nose. Over time the pulley on the crank will loosen off, start to wobble and then start to walk off the crank. When this happens the timing goes and WAMO, catastrophic failure. This problem seems to be caused by back forces from the alternator and the extra power of the 1.9, it's also caused by people not using new crank bolts when the timing belt is replaced. The accepted solution is to machine the cranknose to accept a 1.9TDI crank and install the TDI's clutched alternator pulley. The 1.9TDI's do not suffer this problem. www.vwdiesel.net has many threads on this.
My new to me 1.9TD Golf just started to do the death crank wobble.
Bike Mike
MikeJRA
Bike Mike
ben2go
Diesel Dumby
129
11-19-2010, 07:42 AM #18
(11-19-2010, 12:20 AM)MikeJRA That boat conversion looks cool.
Thanks for that piece of info.
ben2go
AMCtilldeath
Oddball
7
12-01-2010, 02:14 AM #19
(09-13-2010, 04:26 PM)willbhere4u Its an import I have worked on them at the Toyota shop in Berthoud Co the dealers never sold them here! But people brought them in from Canada
let me start out by saying i have found my new home. this forum is just phenominal.
actually, they were imported to the states. check out fueleconomy.gov, click any year and any model, it will show you any and all engine and transmission combos that came available for that specific vehicle. back in the 80's, the two big players in the diesel car world were VW and Mercedes, but there were others too, Peugeot, Renault (the diesel engine offered in the XJ Cherokees) Isuzu, Toyota, Mazda was a VERY big player here too, with there 2.0L diesel being pretty popular (as far as diesel engine option sales went) in the Ford/Mercury Escort/Lynx and Tempo/Tracers, as well as their 626 and pick-ups. Lincoln even got in the game offering the 2.4L turbo diesel from the 524TD in the Mark VII and Continental for a year or two, Mitsubishi, Nissan/Datsun was pretty big too for awhile, GM obviously, Volvo... i think i got most of them... it was allowing the EPA to get the emissions laws passed that they did, as well as corporate cutting corners on Oldsmobile's ORIGINAL design (water seperator (lol) SIX head bolts per cylinder instead of four, higher volume oil pump, etc) of the 5.7L & 4.3L Diesel that ruined light duty diesel automobiles in the US, plus the prohibitive cost of maintaining alot of the above engines, as most repair shops dont want to touch diesels cause they dont know a thing about them
There's no replacement for displacement... except for the TURBO IN MY BASEMENT!Big Grin
AMCtilldeath
Silberpfeil
Slowly Sideways
85
12-03-2010, 09:01 AM #20
(12-01-2010, 02:14 AM)AMCtilldeath There's no replacement for displacement... except for the TURBO IN MY BASEMENT!
I gotta ask---what turbo is that?
This post was last modified: 12-03-2010, 09:03 AM by Silberpfeil.
Silberpfeil
glenlloyd
02-26-2011, 09:30 AM #21
(09-12-2010, 08:15 PM)ForcedInduction
You're right, they did for about 3-4 years IIRC. Here's a pic of a 2LT 2.4L diesel engine I used to have. The 2LT and its turbo variant were available in the states from 84-86 IIRC.
[Image: 2lt2.jpg]
Don't know anything about your van but if it's RWD I would get this one, already setup for same.
[Image: xd3tex.jpg]
This post was last modified: 02-26-2011, 09:35 AM by glenlloyd.
glenlloyd
[Image: 2lt2.jpg]
[Image: xd3tex.jpg]
Waterloo49
10-27-2011, 02:10 AM #22
id say a 4bt cummins if it will fit heighth wise
Waterloo49
10-27-2011, 12:29 PM #23
(10-27-2011, 02:10 AM)Waterloo49 id say a 4bt cummins if it will fit heighth wise
Besides the Cummins being heavy, that would make one bad ass van Big Grin
Waterloo49
10-27-2011, 01:29 PM #24
theres a 69 camaro running a 12v 6bt so the car should handle the weight of a 4bt
Waterloo49
50harleyrider
GTA2359VK
397
07-21-2015, 06:18 AM #25
Depending on the weight of your van, an alh TDI would be pretty awesome and you can get close to 200hp with bolt on mods. Visit the tdiclub conversion forum and look for the ALH-Ford Winstar conversion thread. There is more support for VW diesels out there than any other. You don't even have to change pumps if you go ALH, get the whole donor car and harness and ecu as it is electronic IP and VNT. Far superior to a 1.9 TD too. Lots of conversions on that forum into everything you can imagine.
This post was last modified: 07-21-2015, 06:22 AM by 50harleyrider.
50harleyrider
