Holset HX55 4036892 for Cummins ISX 450
I got a Hypermax HX-50 off of our International 466 hot farm pulling tractor. We dynoed 800+ hp with it if you wanted to crank your ISX up! Just throwin it out there...
You should have asked last year, I sold it on eBay for $150.
Holset HX55 (4036892)
Cummins ISX Signature 450
Compressor
Exducer: 98mm
Inducer: 69.35mm
50 trim
14 blades
Turbine
Inducer: 85.8mm
Exducer: 79.6mm
12 blades
For anyone ever looking for a used turbo I can recommend a place called R&S Distributing in Minooka, Illinois. They reman pretty much every turbocharger as far as I know. I went there once to check it out because a friend and I were going to build a jet engine from a turbocharger. I wanted to buy the turbo that stood waist high but settled for a smaller garrett from an army tank.
Anywho...I always ask for Rich and ask him for a good used core of what you're looking for. Many of the used turbos that are there at R&S are perfectly fine but end up there from engine rebuilders who reman engines.
