STD Tuning Engine Need a marinized OM606? Here you go.
HoleshotHolset
10-15-2010, 09:36 AM #1
http://www.drinkwaardwatersport.com/cate...n-182.html
Prices don't seem that bad compared to what you'd spend on most marinized engines.
Cheers,
Matt
'07 W211 OM642
HoleshotHolset
Cheers,
Matt
'07 W211 OM642
George3soccer
10-15-2010, 11:09 AM #2
What would marinized motors differ from regular vehicle motors.
Just a coating on the motor.
George3soccer
HoleshotHolset
10-15-2010, 02:14 PM #3
(10-15-2010, 11:09 AM)George3soccer What would marinized motors differ from regular vehicle motors.
Most of the time, they're built a little stronger and better suited for sustained high RPM use - compared to an OEM automotive engine. They also have completely different (or no...) emissions equipment and software calibrations. They have the benefit of an unlimited supply of cool water - so they can run things a lot harder (and turn the wick way up...) and not worry about cooling.
I have no idea if these engines are any different than a normal automotive application. I just thought it was pretty darn cool to see a marinized OM606 for sale and figured I'd share that with the other Merc dieselheads.
'07 W211 OM642
HoleshotHolset
'07 W211 OM642
appie
10-15-2010, 03:05 PM #4
Do not compare the prices to new engines,these are used and or rebuild
appie
yankneck696
395
10-15-2010, 06:26 PM #5
All of those engines seem to have heat exchangers (Raw water to cool fresh water/antifreeze), should have bass freeze plugs, indtead of steel, usually have a bit more of a torque cam (gas engines not sure of these), can be reverse rotation, marinized (screened) starter/alternator, many coats of paint, hoses worthy of salt water, water cooled exhaust manifolds & so on.... I'd like to find out if they do reverse rotation internally, or with the transmission, as I have a PennYan with RR & would love to slap a Merc diesel in it without the $2400 ZF reversing 1:1 trans.
yankneck696
10-15-2010, 08:44 PM #6
Couldn't you just spin the prop backwards and get a reverse direction prop???
yankneck696
395
10-16-2010, 04:49 AM #7
The boat is a PennYan with a tunneldrive, prop & ruddder in a tunnel. Rotation is gritical due to strut design & rudder placement. It has been done, but with greatly reduced performance.
yankneck696
HoleshotHolset
10-19-2010, 08:33 AM #8
(10-15-2010, 06:26 PM)yankneck696 I'd like to find out if they do reverse rotation internally, or with the transmission, as I have a PennYan with RR & would love to slap a Merc diesel in it without the $2400 ZF reversing 1:1 trans.
I'd be inclined to think they use a reversing geartrain setup. I've never seen a 'small' diesel setup that way. They spin the really large diesels backwards in some cases...
'07 W211 OM642
HoleshotHolset
'07 W211 OM642
yankneck696
395
10-19-2010, 01:15 PM #9
I'm just hunting for the ZF 1:1 reversing transmission. When I get one at the right price, I'll start on an engine. Till then, the trusty 318 will perservere....
yankneck696
alarm92
10-20-2010, 05:59 AM #10
(10-19-2010, 08:33 AM)HoleshotHolset [quote='yankneck696' pid='19187' dateline='1287185192']
On a boat i worked on a few years ago in Svalbard, we had a 6 cylinder 2000 hp Deutz Engine. Max RPM: 240 RPM frontwards, 200 RPM backwards. That engine we had to turn backwards because we didn't have a gear or pitch on the propeller shaft.
You must have a custom cam shaft that you can move to change timing on the cylinders, you also need a special fuelpump. The camshaft is moved by pneumatic. The engine is also started by 30 Bar (435 psi) Start air.
On very old marine engines that where 1 cylinder and 60 liters they gave it full throttle just befor the piston hits the top position. Then they got a big knock, and the engine started to go backwards. These engines run at very low rpm. from 40-80. They where about 50 hp an 4-5 tons heavy
Most big boats now days have Pitch on the propeller to decide if they want to go backwards or forwards
This post was last modified: 10-20-2010, 06:22 AM by alarm92.
My English might be a bit funky, but i'm from Norway and i kind of sucked in English at school Wink
MB W123 3.0 d turbo project
Audi A4 1.8T 220hk
And a old moped
alarm92
Audi A4 1.8T 220hk
And a old moped
10-20-2010, 07:05 AM #11
On Detroit engines its just a matter of switching the idler gear sides from driving the cam gear to driving the accessory gear.
George3soccer
10-20-2010, 08:44 AM #12
Are the Detroit motors a common choice for marine use.
George3soccer
alarm92
10-20-2010, 10:48 AM #13
(10-20-2010, 08:44 AM)George3soccer Are the Detroit motors a common choice for marine use.
Some of them are 2 stoke, so they are very small en powerful.
My dad had one in his 16 meter Reketråler (google it)
It was a Compressor and turbocharged 2 stoke.. Nosy as hell, but very powerful.
Audi A4 1.8T 220hk
And a old moped
alarm92
Audi A4 1.8T 220hk
And a old moped
yankneck696
395
10-20-2010, 04:46 PM #14
I've worked on alot of Detroits in boats. Great engine. If you ever notice one that isn't leaking oil, shut it down & refill it immediately... Caterpillars are also very common, Mann is starting to get some good usage over here... What I want is the dang diesel Wankel I sawat the Miami boat show years ago. Can't remember who built it, but 6 lobes, 3 turbos & 7500 RPMs.... Dang !!!
yankneck696
George3soccer
10-21-2010, 12:51 PM #15
Oh wow. Sounds like a fun motor really. Any videos on that bad boy
George3soccer
HoleshotHolset
10-22-2010, 07:45 AM #16
(10-20-2010, 04:46 PM)yankneck696 What I want is the dang diesel Wankel I sawat the Miami boat show years ago. Can't remember who built it, but 6 lobes, 3 turbos & 7500 RPMs.... Dang !!!
Was that an OEM marinized engine - or something that was converted? I've hear of diesel radial engines and diesel wankels, but they were both used in military aviation applications.
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
yankneck696
395
10-22-2010, 07:52 PM #17
It was all billet & custom. They had one in a 42' Sportsfish. 40-something knots at 6300 rpm. It was about comparable to a friggin slant 6. cruise was 33 Kn @4500 & fine control down low for maneuvering. They were showing it as a prototype & it did well. If the #'s were right when I was there, they were real efficient & powerful. Smooth & quiet. Weird when you know of all the force being exerted to move that pig so quick.
yankneck696
HoleshotHolset
10-27-2010, 02:40 PM #18
Yeah - moving a 42' boat at 40 kts is no joke.
'07 W211 OM642
HoleshotHolset
'07 W211 OM642
