STD Tuning Engine Minor Modification Best Longevity
Oil Burner
Turbo Everyting!!!
83
10-18-2010, 10:36 PM #1
Doing a Engine swap. 80 non turbo out...85 turbo inBig Grin
This is in a 1980 300CD want to do minor cheap modifications to boost power to 150-200HP, but on the down side I am looking for the best fuel economy, really I'm looking for 35MPG or better.
Here is what has been done:
1. EGR system removed.
2. Turbo Overspeed device in turbo removed and Blocked off.
3. 3" straight exhaust In the works (no mufflers)
4. Any SuggestionsHuh
I wont lie I'm broke but am a diesel mechanic just not a MB diesel mechanic, so any help would be appreciated. If you have photos much easier for me to know what your talking about too.
Oil Burner
E300TSC
Turbo-Supercharged
321
10-19-2010, 05:18 AM #2
That's a tall order. These cars don't have the reserve in the pump that your Cummins has for additional HP just through adjustments. I believe the stock pump is only good for about 140+ HP without going to larger elements.
For MPG, 35 is at the top of the range of what I've seen. Adding a little advance to the pump may help as well as other non-engine related things like cutting a coil off the springs to lower the car a little for better aerodynamics and swapping out the rear end for a taller one.
E300TSC
10-19-2010, 07:16 AM #3
(10-18-2010, 10:36 PM)Oil Burner want to do minor cheap modifications to boost power to 150-200HP
There are none. At minimum you're looking at $1000 for a modified injection pump to break the 150hp mark.
Quote:really I'm looking for 35MPG or better.
The only time you'll see that is driving 45mph on straight level highway. The rest of the time you'll be lucky to break 25mpg IF you drive it easy. If you use 200hp on a regular basis you'll never break 22mpg.
Quote:2. Turbo Overspeed device in turbo removed and Blocked off.
Bad option. Until you get a high output injection pump there is no need for more than 15psi so disabling such a safety device has no benefit at all.
This post was last modified: 10-19-2010, 07:17 AM by ForcedInduction.
Oil Burner
Turbo Everyting!!!
83
10-19-2010, 08:41 AM #4
I used to get 35 out of my 85 300TD no modifications other than Straight exhaust...I live in flat land for the most part.
Thanks for the advice so far.
If I were to remove the Injection pump what mods would I want to do to it and what are good injectors to go with these kind of mods? Remeber longevity is the goal but some HP increase is badly needed after driving the cummins trucksHuh
Oil Burner
10-19-2010, 09:10 AM #5
(10-19-2010, 08:41 AM)Oil Burner I used to get 35 out of my 85 300TD no modifications other than Straight exhaust...I live in flat land for the most part.
I pretty much know you didn't. Its not physically possible due to poor thermodynamics and non-locking torque converter. The stock mufflers are not a restriction. Most likely there was a mechanical error like a blocked tank vent variably altering fill capacity, the wrong speedo from an 82-84 model that had a 3.07 rear end instead of 2.88, larger than stock tires, etc etc.
Even a 240D is lucky to get low 30s if driven nicely.
The only way you'll get 35mpg consistently with an easy 200hp is to get an 87 190D 2.5turbo. If you're set on a wagon the 87 300TD would be able to nearly touch 35mpg while supporting 300hp.
No OM617 powered vehicle will be able to average 35mpg outside of straight low-speed highway cruising.
This post was last modified: 10-19-2010, 09:14 AM by ForcedInduction.
10-19-2010, 09:33 AM #6
My 240d turbo struggles to hit 29-30 mpg with a 4spd manual trans doing anything over 65mph!
Oil Burner
Turbo Everyting!!!
83
10-19-2010, 10:12 AM #7
(10-19-2010, 09:10 AM)ForcedInduction
Here is another theoretical question for you then... Add intercooler to engine, and if anyone knows switch to a 5sp Manual with OD. Has anyone done this and what is the difficulty? What is a good match up for this too Manufacture for trans? Would this increase MPG the intercooler should assist in HP too
Oil Burner
10-19-2010, 08:06 PM #8
(10-19-2010, 10:12 AM)Oil Burner Add intercooler to engine
An intercooler doesn't change anything except allowing more fuel to be injected safely.
Quote:and if anyone knows switch to a 5sp Manual with OD. Has anyone done this and what is the difficulty?
Finding one. I've only ever seen two in person in the last 8 years, one was in a cherry 280CE and the other was trashed from water contamination.
