STD Tuning Engine OM602 Turbo Lag
OM602 Turbo Lag
OM602 Turbo Lag
BSharp
10-19-2010, 01:20 PM #1
Any idea ~what RPM max boost is? On my stock 87 190DT max boost (~12 psi) comes on at about 2700 rpm. Sound right?
This post was last modified: 10-19-2010, 01:55 PM by BSharp.
1987 190DT
BSharp
1987 190DT
10-19-2010, 01:32 PM #2
Being the 2.5 turbo I believe that the engine is actually om605?
BSharp
10-19-2010, 01:40 PM #3
(10-19-2010, 01:32 PM)willbhere4u Being the 2.5 turbo I believe that the engine is actually om605?
Um, yes. You would be correct. Changed it to OM605. Thanks
1987 190DT
BSharp
1987 190DT
muuris
OM605
318
10-19-2010, 01:50 PM #4
OM605 wasn't made in 1987 nor available in 190 chassis. It is OM602.
This post was last modified: 10-19-2010, 01:51 PM by muuris.
muuris
BSharp
10-19-2010, 02:01 PM #5
(10-19-2010, 01:50 PM)muuris OM605 wasn't made in 1987 nor available in 190 chassis. It is OM602.
Grr, you are right. I am really not this bad. Trying to do real work while on the internet is not a good thing. It is a 1987 190DT 602.961 W201
1987 190DT
BSharp
1987 190DT
Deni
10-19-2010, 04:49 PM #6
Depends what gear you're in.
I also have a 190d 2.5turbo but I have messed up with IP, boost controller and LPG injection so boost increases much earlier and faster.
First thing you can do it reduce turbo lag is install a boost controller (~$10 on ebay). You may keep the stock boost pressure but lag will be reduced.
Deni
George3soccer
10-19-2010, 05:07 PM #7
I do recommend, getting a few gauges, to aid in with the tunning on these OM motors.
George3soccer
BSharp
10-19-2010, 05:20 PM #8
Under full throttle in 2nd or 3rd it does not reach full boost until 2700 rpm.
I am planning on getting a boost controller but it should not reduce lag. If the stock wastegate is set to 12-13 psi it does not open until then, hence not bypassing any exhaust. I still have the Alda tamper seal on, I need to adjust it.
(10-19-2010, 05:07 PM)George3soccer I do recommend, getting a few gauges, to aid in with the tunning on these OM motors.
I have a boost gauge mounted under the radio. No egt gauge yet.
This post was last modified: 10-19-2010, 05:22 PM by BSharp.
1987 190DT
BSharp
1987 190DT
10-19-2010, 05:49 PM #9
sorry I wasn't sure about the engine codes in the w201 I thought only the om605 was turbocharged
This post was last modified: 10-19-2010, 05:50 PM by willbhere4u.
Deni
10-19-2010, 06:17 PM #10
(10-19-2010, 05:20 PM)BSharp Under full throttle in 2nd or 3rd it does not reach full boost until 2700 rpm.
As far as I know the wastegate is spring operated so it will start opening gradually until it reaches max aperture where it limits boost.
With a boost controller, the wastegate "doesn't see" boost until the boost controller tells it to. So if you dial the boost controller at about 11psi, the wastegate will start opening only at 11psi and not earlier.
Deni
