STD Tuning Body Mods tilt wheel
tilt wheel
tilt wheel
oldschool5012
10-29-2010, 01:23 PM #1
IdeaIs there a MB factory tilt steering column that will fit a w126?
oldschool5012
10-29-2010, 01:27 PM #2
no not that I'm aware of
10-29-2010, 07:00 PM #3
I don't think that came along until the W140.
85-300Dt
10-29-2010, 11:24 PM #4
I've seen an aftermarket option for w123.
http://crowderscustomizing.com/catalog/q...-85-1.html
http://crowderscustomizing.com/catalog/q...k-742.html
This post was last modified: 10-29-2010, 11:50 PM by 85-300Dt.
10-30-2010, 05:24 AM #5
If the wheel needs to be lower you can just add spacers to the mounting bracket under the instrument cluster. You'll have to remove the studs on the column and install longer ones.
11-01-2010, 03:35 PM #6
W124 has telescoping but no tilt. Its wierd, my 85 200sx even had tilt!
This post was last modified: 11-01-2010, 03:35 PM by winmutt.
