STD Maintenance General how easy/ difficult swapping IP on 606 turbo?
Olivier
11-02-2010, 04:47 AM #1
Still looking around on what to do with my injection pump as I still get fuel starvation, I might get a "donor" pump from another E300Turbo, how easy is it to put it in place? I can lock mine as I got the tool but the new one will be in a different timing/ rotation or what ever.
Can I easily adjust/ rotate the "new" pump to be at the same timing then the "old" one?
Thank you.
Olivier
Olivier
Thank you.
Olivier
