STD Tuning Engine 6mm elements into 'M' type on N/A 617
Alastair E
Moderator?--Nah...
266
11-27-2010, 09:01 AM #1
As I have a spare electronic IP from a 606 I'm thinking of replacing the elements in an 'M' type for a617 thats had moisture damage of its elements, due to poor storage, The rest of the pump is perfectly fine and in fact even spotless inside.
Tomnik has been experimenting with his 7.5mm in a N/A 617 engine and as the injection duration is the shorter than the 5.5mm std. elements for the same quantity delivered has gained power--Without Smoke, and on a N/A engine...
I had initially planned to have a 617 IP modded by Tom for my N/A 617 with the 7.5mm but being made unemployed recently, this and the plan to fit my 606 to a W123 are on hold....
The conversion for 6mm into this already faulty pump should cost me nothing as I can prob. use a proper Test-Bench at a friends diesel-injection shop, and his selection of rollers to set the elements up.
Any thoughts?Idea
[Image: 300TDnoplate.jpg]
Alastair E
Any thoughts?Idea
Jtn190D
MERCEDES DIESEL POWER!
192
11-27-2010, 09:34 AM #2
If it doesn't cost anything why not? I'm sure you could always sell it after you do your om606 swap.
Jtn190D
Alastair E
Moderator?--Nah...
266
11-27-2010, 09:48 AM #3
Well, a few Very Rough calcs suggest this-
A 5.5mm element and a delivery stroke of 1mm will supply 23.76 ish Cubic MM of fuel...
A 6.0mm element and a delivery stroke of 1mm will supply 28.28 ish Cubic MM of fuel....
So, it may be worth exploring....
Alastair E
E300TSC
Turbo-Supercharged
321
11-27-2010, 01:55 PM #4
I think it's a great idea. One project that I've always thought would be cool would be to build a NA engine and optimize the initake/exhaust for best flow with long pipes, porting, etc...
The NA OM606 delivers 148 HP or so. I would think a prepped OM617 with 6mm elements might come close.
E300TSC
Alastair E
Moderator?--Nah...
266
11-27-2010, 03:51 PM #5
(11-27-2010, 01:55 PM)E300TSC I think it's a great idea. One project that I've always thought would be cool would be to build a NA engine and optimize the initake/exhaust for best flow with long pipes, porting, etc...
Well, I'm goona try it I think. Prob be a while to get sorted, Ive got to get the 'test-bed' actually roadworthy first, not much to do, only the brakes...
The N/A 606 has a huge advantage over the old 617, its got a much better volumetric efficiency what with its quad-valve head, so I doubt I could get anywhere near the same powers, but If I was to get say, 100-110 BHP just by changing the elements and without excess smoke or EGT it'll be worth it....
Tomnik using the 7.5mm reckoned the acceleration was hugely different to before, probably due to the shorter injection duration for the same quantity of fuel....
Alastair E
E300TSC
Turbo-Supercharged
321
11-27-2010, 04:33 PM #6
I'd be willing to bet that if you created long tube intake/exhaust with velocity stacks and ported the head, you could get some good flow numbers out of it.
E300TSC
11-27-2010, 07:15 PM #7
sound like a good base for a supercharger set up!
Alastair E
Moderator?--Nah...
266
11-28-2010, 10:01 AM #8
(11-27-2010, 07:15 PM)willbhere4u sound like a good base for a supercharger set up!
Hmm, Dunno about that....
I'm working with all Non Turbo machinery. Turbo 617 is rarer than hen's teeth here....
Would love to fit a turbo with just a little boost to my 'nice' wagon below, but for experiments I'm going to mod up the 'test-bed' which is my 280TE/300TD 'conversion', which structurally and mechanically is a great car but doesn't look pretty,--in fact it wouldnt look out of place on a Mad-Max film!Tongue....
--Nothing a GOOD re-spray wouldnt put right thoughIdea
This has a fully re-built 617 N/A engine which I had re-bored and has had all parts replaced. All the conversion work, wiring and other tedious stuff is completed, and it runs. Halfway through rebuilding braking system and trying to find why ABS doesn't work--but sure Thats all to do with my faulty OVPBig Grin
Shouldnt take long, just need to spend a day or so doing it....
Alastair E
dude99
11-28-2010, 05:24 PM #9
hmm, I never thought there was any more power to be gotten out my my NA617. I'll be watching this closely. If there's a way to add a little more zip to my '79 I'm interested...
This post was last modified: 11-28-2010, 07:32 PM by dude99.
dude99
11-29-2010, 12:46 PM #10
There are special tools needed to get the elements in and out (removing cam shaft). This is what stalled my work on similar project.
Alastair E
Moderator?--Nah...
266
11-29-2010, 12:56 PM #11
(11-29-2010, 12:46 PM)winmutt There are special tools needed to get the elements in and out (removing cam shaft). This is what stalled my work on similar project.
Nah, I have access to a full 'Injection-Shop' and as I recall, there are pins you shove in holes to hold the spring/roller up to allow the cam to be removed....
Either way, it souldnt be much of an issue for my 'tame injection guy'...Big Grin
Alastair E
tomnik
11-29-2010, 03:45 PM #12
Hi,
about 55ccm/1000 was the delivery my friend's 617 N/A could burn (without excessive smoke) with 7mm elements.
Tom
tomnik
Hi,
Tom
Alastair E
Moderator?--Nah...
266
11-29-2010, 05:24 PM #13
(11-29-2010, 03:45 PM)tomnik Hi,
Tom
Ah, Cheers Tom!
I was wondering how much I could initially set the pump for, I was going to set at std. plus a little more, then tweak from there.
I'll set to 55ccm/1K, hopefully there will be sufficient delivery in the required time with my much smaller 6mm elements....
--Just to confirm, This is 55/1k before foldback of governor?
Alastair E
Tom
Ah, Cheers Tom!
tomnik
11-30-2010, 01:12 AM #14
Hi Alastair,
55 ccm is max. delivery, adjusted on the lower left screw behind the governor cover.
I got it back from the shop with higher adjustment and we adapted it to the car and put it back on the bench to get the data.
Tom
tomnik
Hi Alastair,
Tom
Alastair E
Moderator?--Nah...
266
11-30-2010, 04:25 AM #15
(11-30-2010, 01:12 AM)tomnik Hi Alastair,
Tom
Ah, great. 55/1K it is then....
Any idea what the 'std' quantity was for the N/A 617?
Alastair E
Tom
