STD Other FS / WTB / Buying guides WTB T3 to GT22V turbo adapter
Biohazard
Smokin like a champ!
376
12-15-2010, 09:11 PM #1
As the title says, I need an adapter to mount my GT22V turbo to the stock Mercedes manifold. I know some of you guys here have made them before, wondering if anyone has a spare they wouldn't mind selling. Thanks in advance.
This post was last modified: 12-16-2010, 12:54 PM by Biohazard.
Biohazard
12-15-2010, 10:09 PM #2
I think they sell them on eBay!
aaa
12-15-2010, 10:34 PM #3
I'm making them via waterjet. The dude said $90 for stainless 1/2" thick, I figure it could get a tad cheaper if I went thinner or mild steel or something. And probably cheaper if I make a quantity of them, but I'm not sure what the demand is.
aaa
Biohazard
376
12-16-2010, 09:50 AM #4
I haven't looked on ebay for a while, but don't remember seeing them. I'll check again. The waterjet one sounds nice, but the price is a bit more than I was hoping to pay. Either way, let me know how the waterjet one turns out. I'm between housing for a bit and don't have the workspace or time to fab one up.
EDIT: forgot to put the "V" at the end of GT22... forgot the regular has a 4 bolt pattern.
This post was last modified: 12-16-2010, 12:58 PM by Biohazard.
Biohazard
MTUPower
288
01-16-2011, 10:19 AM #5
I have to mount my Liberty CRD turbo to my 617 powered wagon to give the Myna pump the air it needs. Who has a adaptor for sale so I can start the process? It's not a "22" but a "20" version.
This post was last modified: 01-16-2011, 10:20 AM by MTUPower.
MTUPower
01-16-2011, 11:08 AM #6
(01-16-2011, 10:19 AM)MTUPower I have to mount my Liberty CRD turbo to my 617 powered wagon to give the Myna pump the air it needs.
A Liberty turbo won't flow more than the stock T3, but the response difference is fantastic.
01-16-2011, 07:35 PM #7
(01-16-2011, 11:08 AM)ForcedInduction
Yeah sell the GT2056v to some TDI'er, I would think you would need a GT2359V or a GT2360V to make your Myna pumped engine happy.
MTUPower
288
01-16-2011, 08:03 PM #8
Okay someone point me to both the adaptor and the turbo...
ebay has several 2060's as low as $430. I'd still need an adaptor and a control method/mechanism + new exhaust system.
This post was last modified: 01-16-2011, 08:15 PM by MTUPower.
MTUPower
01-16-2011, 08:13 PM #9
(01-16-2011, 08:03 PM)MTUPower Okay someone point me to both the adaptor and the turbo...
Here is some information for you to digest on the GT2359v or GT2360v.
http://www.superturbodiesel.com/std/vnt-...t-235.html
GT2359v can be found on Mercedes e320 CDI but are electronically actuated. Look around - forums, ebay, etc, probably you'll get it from Europe.
GT2360v can be found on US eBay.
http://cgi.ebay.com/ebaymotors/Turbochar...1314wt_939
As far as adapter, You'll need to make it up yourself.
MTUPower
288
01-18-2011, 07:52 PM #10
(01-16-2011, 08:13 PM)DeliveryValve
Yeah I saw that one- but is it really worth the extra (perhaps) $300? over a liberty turbo? Can it be controlled the same way?
This post was last modified: 01-18-2011, 07:53 PM by MTUPower.
MTUPower
aaa
01-18-2011, 08:30 PM #11
(01-18-2011, 07:52 PM)MTUPower Yeah I saw that one- but is it really worth the extra (perhaps) $300? over a liberty turbo? Can it be controlled the same way?
You can find Sprinter gt22's for 100-200 every once in a while, usual ebay rules apply (good chance of it being a dud). They can be controlled the same, in fact the older ones come with the pressure actuator attached. Not sure what you meant by "controlled", all these garrett turbos have more or less the same little arm on them.
I believe that particular GT2360V would need the exhaust reclocked. I had messaged that ebay dude and confirmed that it's effectively upside down from on om617's perspective (in terms of oil supply/drain). Or you can just mount it with the exhaust pointing forwards heh.
I think you should go with what you got, and when the opportunity for a cheap bigger turbo comes along jump on it. There was a diagram of the gt20 flange floating around on this forum somewhere but it didn't have any measurements on it though.
Here we go, I found the GT2056v measurements. Didn't find the thread though so I don't remember who made it.
This post was last modified: 01-18-2011, 08:36 PM by aaa.
aaa
01-18-2011, 09:11 PM #12
(01-18-2011, 08:30 PM)aaa
I believe that particular GT2360V would need the exhaust reclocked. I had messaged that ebay dude and confirmed that it's effectively upside down from on om617's perspective (in terms of oil supply/drain). Or you can just mount it with the exhaust pointing forwards heh....
It's really up to you. I think it would be worth it though. From your videos, your putting out a lot of black smoke, a 50 or 55 trim (GT 2359v or GT2360v) would help make it cleaner. For my motor, I think will be going that route instead of the GT2256v that I have.
SurfRodder took the GT2360v apart and will be able to reclock it. So that should be fine.
http://superturbodiesel.com/std/vnt-vgt-...l#pid17982
The GT2256v needs to reclocked to fit one the 617 and I believe the GT2056 also needs to be reclocked.
This post was last modified: 01-18-2011, 09:16 PM by DeliveryValve.
01-19-2011, 09:39 AM #13
I still have the blank for my gt2056v adapter.
Biohazard
376
01-24-2011, 09:43 AM #14
I've ordered up some exhaust bends from Mcmaster Carr, I'm just going to build a new manifold. Nothing fancy for this one, just a different style log manifold with a GT22V flange. This will be the first manifold I've made, so I'm going to try to keep it simple. If it works, great. If not, then I guess I try again. Smile
Biohazard
