STD Tuning Engine Cheap OM617 performance
Robert_UAH
01-07-2011, 11:13 AM #1
Ok so I am going to be building a car for the Grassroots Motorsports $2011 Challenge. Basically it is a competition in which you have to build a car for under the $2011 budget cap and do a autocross, drag race and concours competition. So the car I am going to be getting has had a OM617 from a '83 300TD swapped in. It isn't a Mercedes car. It was a car that was started for the challenge a few years ago but wasn't finished and pasted on to someone else now I will be getting it. I will have $550 in the car right off the bat and I need to fabricate a driveshaft, finish some wiring and obviously upgrade the suspension. So I was wondering with the left-over money, what are the most cost effective modifications? From what I have been reading the IP is a big limiter in this engine and cost $$$$ to get a better one, am I off here? It seems from what I have read the W115 intake manifold is the one to get. These cars are a T3 pattern correct?
I should have said it is a OM617a
This post was last modified: 01-07-2011, 11:51 AM by Robert_UAH.
Robert_UAH
led-panzer
01-07-2011, 12:36 PM #2
Yea its a t3. If you want cheap, look into cutting the collars on the delivery valves and hogging out the injectors, but doing that you will need a good intercooler.
1985 300D 280,000 miles RIP
led-panzer
Robert_UAH
01-07-2011, 12:57 PM #3
I was thinking of putting a Holset off a Cummins on it and a junkyard intercooler.
Robert_UAH
George3soccer
01-07-2011, 01:07 PM #4
Good choice on the turbo but not for that motor and the limited fuel. Your better off with a k26 kkk turbo or something larger possibly a t04 with an intercooler.
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
Robert_UAH
01-07-2011, 01:23 PM #5
I thought the KKK K26 turbo had a different flange then the T3. As far as I know the T04 is much more difficult to find in the junkyard then the Holset which is why I was leaning towards that. But if it can't take the turbo, I will look for something else. Most of my experience with automobiles has been Civics, MGs, Yamaha 2-strokes and Suzuki 600s so take that for what it is.
(01-07-2011, 12:36 PM)led-panzer Yea its a t3. If you want cheap, look into cutting the collars on the delivery valves and hogging out the injectors, but doing that you will need a good intercooler.
What does cutting the collars on the delivery valve do?
This post was last modified: 01-07-2011, 01:30 PM by Robert_UAH.
Robert_UAH
jonbobshinigin
01-07-2011, 03:11 PM #6
Your problem will be fuel, not air flow to start with. For the turbo were you thinking HY35 or HX35? If so, it is too big, especially without enough fuel. There should be a writeup somewhere one a "full load adjustment" on your IP/Injection Pump. That will probably be the best place to start.
1987 300TDT - 260,000 Miles
jonbobshinigin
Robert_UAH
01-07-2011, 03:41 PM #7
HX35.
(01-07-2011, 03:11 PM)jonbobshinigin Your problem will be fuel, not air flow to start with. For the turbo were you thinking HY35 or HX35? If so, it is too big, especially without enough fuel. There should be a writeup somewhere one a "full load adjustment" on your IP/Injection Pump. That will probably be the best place to start.
Is this the writeup you are taking about?
http://www.superturbodiesel.com/std/ip-f...t-189.html
This post was last modified: 01-07-2011, 03:54 PM by Robert_UAH.
Robert_UAH
HX35.
Geezer
01-07-2011, 05:09 PM #8
what's the 617 in?
Geezer
what's the 617 in?
01-07-2011, 06:07 PM #9
(01-07-2011, 03:41 PM)Robert_UAH HX35.
Yup thats the one!
Also do any maintenance that has been forgotten about.. Valve job, cam timing, IP timing, fuel filters.. all that will help the engine run its best, they will all make a difference. Boost should be around 12-14. If you can rebuild the injectors, do that as well. You could just put a larger comp wheel in the stock turbo instead of buying something else. I put a 60 trim in mine (the stock wheel is a 45 trim Garrett T3).
Yup thats the one!
01-07-2011, 06:28 PM #10
$2011-$550=$1,461
Barely enough to buy a high output injection pump. If you spend the money on anything else you'll never see more than 160hp, no matter what turbo you use.
$2011-$550=$1,461
Robert_UAH
01-07-2011, 06:54 PM #11
(01-07-2011, 06:28 PM)ForcedInduction $2011-$550=$1,461
But $2011-$550-used race slicks-suspension upgrades-driveshaft-radiator will not be enough to buy a high output injection pump. Considering the original was rated at just over 100hp at the crank. Around 140-150hp would be nice for the time being.
Robert_UAH
01-07-2011, 07:00 PM #12
If you're going to use the stock injection pump then there isn't much point in increasing turbo airflow. The stock turbo can more than handle everything the stock injection pump can put out. If anything, you should go to a smaller turbo for better response.
This post was last modified: 01-07-2011, 07:01 PM by ForcedInduction.
Robert_UAH
01-07-2011, 07:14 PM #13
So what can I do other then maintenance? Turn up the boost and bigger exhaust? After the Challenge the car will be getting a high output pump and a lot of other goodies in preparation for Targa Newfoundland.
Robert_UAH
Robert_UAH
01-08-2011, 10:56 AM #14
(01-07-2011, 05:09 PM)Geezer what's the 617 in?
Mazda Miata
Robert_UAH
Mazda Miata
Silberpfeil
Slowly Sideways
85
01-17-2011, 06:36 AM #15
(01-07-2011, 07:14 PM)Robert_UAH So what can I do other then maintenance? Turn up the boost and bigger exhaust? After the Challenge the car will be getting a high output pump and a lot of other goodies in preparation for Targa Newfoundland.
How serious are you about the Targa?
Are the rules still extensively cantered towards the vintage classes?
One of my fav Targa Newfoundland cars was an Escort RS 2000 with a modern 2.3 L Ford turbo 4 making over 400 hp
Silberpfeil
Robert_UAH
01-18-2011, 09:35 AM #16
I want to do it. It will be a Challenge car first and then it will all come apart to put a '99-'05 Miata front subframe and a lot of extra stiffening (like the Flyin' Miata butterfly brace) and AFCO dampers and extra horsepower. I am not sure how competitive I can be but I want to take a shot.
Robert_UAH
dalek
08-08-2011, 07:54 AM #17
Resurrecting thread, but wouldn't that make the Miata rather nose-heavy?
I am not here to make waves; Sois jeune et tais toi
dalek
98taco3
08-08-2011, 02:59 PM #18
(08-08-2011, 07:54 AM)dalek Resurrecting thread, but wouldn't that make the Miata rather nose-heavy?
Seems to me it would be offensively heavy in the front end and under steer like crazy. Even with redesigning the suspension. You would be talking quite a bit of modification that just swapping in another years stock stuff would not accomplish.
98taco3
dalek
08-08-2011, 03:12 PM #19
Mid engine?
dalek
Mid engine?
