603 pump
603 pump
Hi
My engine 603.960
My pump nr is 0400 076 986
Can I use 0400 076 975 pump from 124 1988 300D
http://en.bildelsbasen.se/?link=item&post_id=20304116
Thanks
Regards
Atli
Yes, but you will lose 40hp because that one is for a non-turbo engine.
That on top is the shutoff actuator. Middle back is idle speed control. Bottom back is anti-jerk control which means that pump was for a manual transmission, which also means it was non-turbo since MB didn't make any turbo models without an automatic.
(01-10-2011, 02:37 AM)Atli(01-09-2011, 08:06 PM)ForcedInduction Yes, but you will lose 40hp because that one is for a non-turbo engine.
I thought I sow ALDA on the picture with it!!
Are you shoer it is non turba?
Regards
Atli
Hi Atli,
either get a turbo governor or get a complete turbo IP.
Currently I am "playing" with different pumps and adjustments.
My 603 turbo pump with 7.5mm elements is out of the car for readjustment of the governor as I was not totally happy with the adjustment.
Right now I am installing another pump with 7mm elements which was originally for a friend but he sold his car before my pump guy could finish it.
A third pump is in progress for 7.5mm elements and adjustment according the results of the first.
Somewhen I can offer you a pump (7 or 7.5mm) that was already tested in the car.
Depending on your schedule this can be an option.
Tom
Regards
Atli
(01-10-2011, 02:52 AM)ForcedInduction That on top is the shutoff actuator. Middle back is idle speed control. Bottom back is anti-jerk control which means that pump was for a manual transmission, which also means it was non-turbo since MB didn't make any turbo models without an automatic.
I can't really tell. Nothing in the description says for sure if its turbo or not.
(01-10-2011, 04:08 AM)ForcedInduction I can't really tell. Nothing in the description says for sure if its turbo or not.
(01-10-2011, 04:47 AM)tomnik Atli,
the ... 961 is a turbo pump
and 124 193 ..is also an indication for turbo.
But 260 EUR is (too) much for that.
max. 150 EUR for a nice one o.k. but 260 ?
Tom
Tom
from time to time a turbo pump comes up on ebay.de for that money or less.
Did you contact Scott for your pump that you sent to David?
Arjan can also install the Floyd elements...
As I wrote before I am sending back my Floyd IP to Berlin for a re-adjustment of the governor (on guarantee) and collecting the settings.
This pump or the one with the 7mm elements will be for sale after I tested them in my car and have the third pump running.
Tom
(01-10-2011, 05:37 AM)tomnik from time to time a turbo pump comes up on ebay.de for that money or less.
Tom
Tom
