STD Tuning Engine Basic OM606 (or OM648?) questions
shane
01-10-2011, 12:52 PM #1
Trying to get my hands on good info about a swap I'm planning. I've been looking at the OM606 (turbo) as the most likely candidate. This engine would go into a Toyota Land Cruiser, so obviously it's not plug-n-play.
If I were to go with a manual transmission, I'd have to ditch the transmission electronics of course. When you unplug/remove the automatic transmission module, does the engine ECU care (by throwing a code or otherwise)?
I understand there is a speed sensor on the wheels with the 722.6 transmission, is that true? It's the 722.6 that is in the 98-99 E300Ds, right?
Related to all this, I understand the OM648 is the OM606 with CDI. That would be nice to have but I'm concerned about getting into a mess with the electronics. I don't mind moving modules and wiring harnesses at all, and I actually like the efficiency that electronic controls provide. I just don't want to get into issues with VIN-locked ECUs and such but am not positive this would be an issue. Is anyone able to shed light on that?
Feedback on any of this would be much appreciated! I'm looking for a wrecked car to purchase but want to avoid getting one and then hitting a brick wall of an issue halfway through the whole thing, so I'm in the unfortunate spot of not having a car in hand for reference.
shane
01-10-2011, 01:42 PM #2
(01-10-2011, 12:52 PM)shane When you unplug/remove the automatic transmission module, does the engine ECU care (by throwing a code or otherwise)?
Yes. The engine uses a CAN, so it expects to get inputs from the transmission and several body controllers.
Quote:Related to all this, I understand the OM648 is the OM606 with CDI.
No. The CDI engines have nothing in common with earlier engines.
Your best option is to replace the OM606 electronic pump with a mechanical one. There isn't any benefit in trying to swap over electronics on that engine.
shane
01-10-2011, 01:58 PM #3
(01-10-2011, 01:42 PM)ForcedInduction
Thanks, I was afraid of that. What are the body controllers?
OK -- I had thought that there was a CDI I6 that was similar to the OM606. I know the V6s are completely different.
Quote:Your best option is to replace the OM606 electronic pump with a mechanical one. There isn't any benefit in trying to swap over electronics on that engine.
Not even an MPG benefit?
shane
01-10-2011, 02:12 PM #4
(01-10-2011, 01:58 PM)shane Thanks, I was afraid of that. What are the body controllers?
Instrument cluster, pedal inputs and security, just that I can recall off my head.
Quote:OK -- I had thought that there was a CDI I6 that was similar to the OM606. I know the V6s are completely different.
The I-6 layout is the only thing they have in common.
Quote:Not even an MPG benefit?
The electronic pump does nothing the mechanical governor can't. The only reasons MB used one is for OBDII compliance and tighter emissions controls.
shane
01-10-2011, 05:45 PM #5
(01-10-2011, 02:12 PM)ForcedInduction
Then I would need to figure out if my local smog inspector will go for a mechanical IP with the swap. Maybe the inspector will go for it if I call it a 603, which might still fit the requirements. What they want to see is an engine same year or newer than the car, in the same weight class as the car, with the stock smog equipment the engine came with -- they want to see you're not creating a dirtier vehicle than it was originally. That's one reason I'm interested in the electronics.
Let me ask this: if I were to swap all the wiring/etc over -- yes, including dash, pedals and key switch -- am I missing anything in thinking that this would allow everything to work correctly? The only thing I can think of that might throw it off is if the ECU cares about vehicle speed -- in which case it would be off because the tire size will be significantly different than the Mercedes.
shane
erling66
SuperDieselVan
294
01-10-2011, 07:11 PM #6
(01-10-2011, 05:45 PM)shane Let me ask this: if I were to swap all the wiring/etc over -- yes, including dash, pedals and key switch -- am I missing anything in thinking that this would allow everything to work correctly? The only thing I can think of that might throw it off is if the ECU cares about vehicle speed -- in which case it would be off because the tire size will be significantly different than the Mercedes.
I just took out a om606 and tran from a w210 e300 and thought that maybe I could just take out all the electronics for the engine and put everything in a W124 and the electronic IP would work? I took out all the cables and electronic boxes from the car. But you can not separate engine and ECU cables from the rest, everything is connected!!!! and I mean everything, I couldn't even separate the lightening cables from the rest. So unless you are a car electrician, forget it. Go for a mechanical IP
erling66
E300TSC
Turbo-Supercharged
321
01-10-2011, 08:02 PM #7
The 210 is a crap storm of wiring and computers. I would totally forget trying to make a meaningful swap of it. I would do one of the following:
Call the OM606 a "95" (no OBDII), use an OM603 mechanical pump and swap over the 6mm pump elements from the 606 pump. Find an emissions sticker from a 95 and make the engine 95 compliant - basically EGR I think is all they had.
Or, use the OM606 with the electronic pump and get with some of the guys on here that have developed a standalone controller for the engine.
The first option I believe, is the most attractive one.
E300TSC
shane
01-11-2011, 02:24 PM #8
(01-10-2011, 07:11 PM)erling66 I just took out a om606 and tran from a w210 e300 and thought that maybe I could just take out all the electronics for the engine and put everything in a W124 and the electronic IP would work? I took out all the cables and electronic boxes from the car. But you can not separate engine and ECU cables from the rest, everything is connected!!!! and I mean everything, I couldn't even separate the lightening cables from the rest. So unless you are a car electrician, forget it. Go for a mechanical IP
That's aggravating. I guess they don't make it easy. I don't suppose there's any way to leave it all connected? I know it's all plugged into the dash panel, the DAS and all that.
(01-10-2011, 08:02 PM)E300TSC The 210 is a crap storm of wiring and computers. I would totally forget trying to make a meaningful swap of it. I would do one of the following:
I may have to do the mechanical pump. The standalone controller might be nice to try but I'm sure the smog folks won't go for it, so that would have to wait until after the inspection. Is there anyone who's figured it out besides "dervtuning" who seems to have gone MIA for a few months now?
Also figured out last night that all the electronics, even in the 98-99, are VIN-locked too, though there does appear to be a way to disable that.
shane
greg123
01-11-2011, 08:31 PM #9
What about electronic cruise control? And gearbox cutting engine for smooth upshifts and blipping it on downshifts? Perhaps not a massive relation to this swap, but surely some reasons if one was to keep all the merc electronics?
Greg.
[/quote]
greg123
Greg.
[/quote]
shane
01-12-2011, 02:57 PM #10
(01-11-2011, 08:31 PM)greg123 What about electronic cruise control? And gearbox cutting engine for smooth upshifts and blipping it on downshifts? Perhaps not a massive relation to this swap, but surely some reasons if one was to keep all the merc electronics?
True, wouldn't hurt to have those.
One aspect that makes the prospect of this slightly simpler is that the Land Cruiser has no electronics that I'm intent on keeping. There's a basic ECU that will go out with the old engine, and everything else is mechanical and/or basic two-wire switch stuff. So at least I don't have to merge two systems, that would make it pretty much impossible.
Defeating the VIN lock in the Drive Authorization System appears doable, so my current concern is the air bag (and similar things I'm not thinking of) that would be difficult to move but probably cause the computer to have a fit if I unplugged.
shane
gn3dr
01-12-2011, 05:18 PM #11
(01-12-2011, 02:57 PM)shane
I'm planning on something similar myself but I'm putting an OM606 into a 1979 Jaguar. Haven't started yet but I am planning to keep the electronic pump and ECU. I am only startring to research it and probably need to buy the wiring diagrams but it must be doable. I mean at the end of the day it's only wiringRolleyes
I've bought a complete 99 E300 TD as a donor so I will have everything there in front of me to be able to pick apart the wiring. If I do start to make some progress in figuring out the management system connections I will post on here.
Can anyone recommend a good source for the wiring diagrams for this car (i.e. free on the internet somewhere Big Grin)
gn3dr
Riverstick
01-12-2011, 05:47 PM #12
[/quote]
I'm planning on something similar myself but I'm putting an OM606 into a 1979 Jaguar. Haven't started yet but I am planning to keep the electronic pump and ECU.........
[/quote]
There's a massive ammount of work and head balding figuring out to be done with that project.....do-able but stress-able
Riverstick
[/quote]
[/quote]
greg123
01-12-2011, 06:15 PM #13
Sounds like it will suit you well. I think you'll find airbags and instruments etc are normally stand alone, most vehicles you can leave the airbags in just fine and keep the safety. Immobliser and instrument interface with engine ecu is harder on canbus cars but on older cars often it's just a case of wiring up some sensors.
Greg.
(01-12-2011, 02:57 PM)shane True, wouldn't hurt to have those.
Very interesting, I have a s1 1969 XJ6 SWB and initially wanted to put a built US V8 in it. Recent years I fancied a big diesel and mwm's 4.2 straight 6 would be fantastic (think merc engines are good - that bad boy is amazing - stock internals 550hp with fueling/turbo, bolts to GM auto boxes, used in Brazil in GM trucks, simple design similar to a 200tdi land rover and very economic di 2-valve engine with a bosch pump) but getting one here is hard. I know of one for sale in Europe, for a few thousand....
So maybe a Merc engine may be the way to go.
Greg.
[/quote]
This post was last modified: 01-12-2011, 06:18 PM by greg123.
greg123
Greg.
Greg.
[/quote]
erling66
SuperDieselVan
294
01-12-2011, 06:30 PM #14
(01-12-2011, 05:18 PM)gn3dr I'm planning on something similar myself but I'm putting an OM606 into a 1979 Jaguar. Haven't started yet but I am planning to keep the electronic pump and ECU. I am only startring to research it and probably need to buy the wiring diagrams but it must be doable. I mean at the end of the day it's only wiringRolleyes
I hope you will succeed and tell us about itRolleyes
As you can see from my previous post, I gave up(I am a mechanic, not an electrician)
I heard that someone in Germany can rebuild the ECU to make it programmable but it is not cheap.
You can download the Mercedes Benz WIS ASRA if you have a torrent program or buy a copy on Ebay. There you find the wiring diagram(and lots of other stuff too)
erling66
shane
01-12-2011, 11:13 PM #15
(01-12-2011, 06:15 PM)greg123 Sounds like it will suit you well. I think you'll find airbags and instruments etc are normally stand alone, most vehicles you can leave the airbags in just fine and keep the safety.
I would hope so, but have been afraid that those too are connected to the CANBUS. I do know that current recent models have an airbag controller, which on any sign of trouble will tattle to the ECU and cause a DTC.
But the problem is that I don't yet have a car in front of me, so I don't necessarily know if this is something that was present in the 98-99 year or was introduced later.
I think the instrument cluster is connected to the CANBUS though in the 98-99 models, right? Heck, I don't know that definitively either though.
Cool, that would be a really interesting swap. You're ahead of me in the respect that you've got a donor car! My present lack of one makes me a little blind on these things. Your swap is also somewhat similar in that I imagine your Jag's existing wiring/electronics are pretty basic.
Please do share things as you find them or figure them out and I will do the same. I'm especially wondering what all is hooked up to that CANBUS. Yeah, it is all wiring, but the interoperation of everything on the CANBUS makes it an entirely different situation because several models expect to be talking to each other.
I figure my first task, after I get at the wiring and see what's all in there, is to try disconnecting various things and testing if the ECU still works, still starts the engine and doesn't throw any errors. That will tell me if I have more problems to solve besides the Drive Authorization System.
(01-12-2011, 05:18 PM)gn3dr Can anyone recommend a good source for the wiring diagrams for this car (i.e. free on the internet somewhere Big Grin)
Ask your local library if they subscribe to the EBSCO databases, and if one of those is the EBSCO ARRC (Auto Repair Reference Center). They may also be able to provide a user/pass for online access at http://search.ebscohost.com/
This post was last modified: 01-12-2011, 11:56 PM by shane.
shane
E300TSC
Turbo-Supercharged
321
01-13-2011, 06:51 AM #16
Reading through this again, I'm wondering if they emissions guy think that the electronic version of the pump is somehow "cleaner" than the mechanical version.
The electronic pump is just a mechanical pump with an actuator that moves in response to a throttle position sensor. The ECU also mimmicks the action of the ALDA by waiting for sufficient boost before allowing fueling. The ECU doesn't exert direct control on each injection event like the HUEI or CR engines.
E300TSC
shane
01-13-2011, 04:36 PM #17
(01-13-2011, 06:51 AM)E300TSC Reading through this again, I'm wondering if they emissions guy think that the electronic version of the pump is somehow "cleaner" than the mechanical version.
Not necessarily, but to avoid confusion, they want to see that an engine from 1999 has all the stock equipment from 1999. Knowing that, and checking for fault codes, they can be reasonably sure the engine will continue to operate within the requirements from when it was made. I haven't yet discussed it with them and I may be able to get them to approve a 1999 engine with a 1995 injection pump so long as I can document that the engine is equipped exactly as a 1995 engine would be.
(Edit: You may then be asking, why not just use the 95 OM603? Because I'd like to avoid the problems I understand the OM603 had, and I want the extra power the 4v head + turbo provides. I'm asking this engine to move a 4200-lb truck.)
(01-13-2011, 06:51 AM)E300TSC The electronic pump is just a mechanical pump with an actuator that moves in response to a throttle position sensor. The ECU also mimmicks the action of the ALDA by waiting for sufficient boost before allowing fueling. The ECU doesn't exert direct control on each injection event like the HUEI or CR engines.
So you're saying that it isn't any more precise than the mechanical version? I guess I assumed it was -- with many other engines that's true, but I should know by now that Mercedes builds things their own way.
I had looked up the MPG for a 1995 vs. 1999 E300D and the latter is rated for 3 mpg more. Not a huge difference but not insignificant either, over the course of its life. The difference could also be due to the 4-valve head in the 1999 version.
This post was last modified: 01-13-2011, 05:22 PM by shane.
shane
aaa
01-13-2011, 06:32 PM #18
(01-13-2011, 04:36 PM)shane
There is no 95 om603. The 95 is a mechanical om606.
aaa
shane
01-13-2011, 06:36 PM #19
(01-13-2011, 06:32 PM)aaa There is no 95 om603. The 95 is a mechanical om606.
Yeah, was just figuring that out. So it's the 94 om603 that I was talking about, the 95-97 om606 isn't good for me because it doesn't have a turbe and as I understand it doesn't hold up to a turbo.
shane
greg123
01-13-2011, 06:58 PM #20
Can't you just get it to pass a smoke test for the annual test (mot here) as unless you overfuel, whatever sort you get should pass current test regs and then use that as evidents your 'who knows what it is' motor is clean enough?
greg123
shane
01-13-2011, 07:03 PM #21
(01-13-2011, 06:58 PM)greg123 Can't you just get it to pass a smoke test for the annual test (mot here) as unless you overfuel, whatever sort you get should pass current test regs and then use that as evidents your 'who knows what it is' motor is clean enough?
Yeah, but the key is getting the swap approved. If I just go down to the local smog inspection station and they see that the VIN indicates a gasoline engine but there's a diesel in it, they'll definitely just send me out the door. Once the swap is inspected, that gets it titled as diesel and it's just smog tests from that point forward.
shane
E300TSC
Turbo-Supercharged
321
01-13-2011, 08:02 PM #22
So, do they have a record of the specs for every engine from every year? My idea is to use the 98-99 engine/block/manifolds with a 95 pump and call it a 95. Then, it's pre-OBDII so no codes. How do they know what year the engine is? The only thing I can think of is that they look up the date code on the block. Then again, it could be a rebuild and have no date code or an incorrect one. (Just thinking out loud).
What year is the Toyo?
E300TSC
shane
01-14-2011, 10:03 PM #23
(01-13-2011, 08:02 PM)E300TSC So, do they have a record of the specs for every engine from every year? My idea is to use the 98-99 engine/block/manifolds with a 95 pump and call it a 95. Then, it's pre-OBDII so no codes. How do they know what year the engine is? The only thing I can think of is that they look up the date code on the block. Then again, it could be a rebuild and have no date code or an incorrect one. (Just thinking out loud).
They might, I don't know. Ideally they'd like to see a receipt and VIN number from the donor car. I could buy a junker 95 engine from a yard somewhere and use the VIN from that. I looked up the wiring diagrams for the 95 though. The ISC control module (hooked to several other things) and EGR control module look important. I can't tell how easy those modules and wiring would be to transplant onto a 99.
(01-13-2011, 08:02 PM)E300TSC What year is the Toyo?
1991.
shane
1991.
Volker407
naturally aspirated
157
02-03-2011, 12:15 PM #24
As it is a Landcruiser, did you think of using a Toyota 1KZ-T or 1KZ-TE engine from the prado? This would make the swap much easier (if that is desired)
both engines have:
4 cylinder
Displacement 3.0L , stock 125hp, 300NM torque (european version)
swirl chamber and Denso distributor pump (a Bosch copy)
cast iron block, aluminum head, 2 valves per cylinder, 2 balancer shafts
the australian versions had a stock intercooler with which you get approximately 140-150hp and 340NM torque
1KZ-T is a mechanical pump
1KZ-TE is an eletronically controlled pump, but no CAN Bus or anything
as much as i can remember the engine was produced from ~1987 until 2001
Gruß Volker
Volker407
both engines have:
4 cylinder
Gruß Volker
shane
02-03-2011, 01:46 PM #25
(02-03-2011, 12:15 PM)Volker407 As it is a Landcruiser, did you think of using a Toyota 1KZ-T or 1KZ-TE engine from the prado? This would make the swap much easier (if that is desired)
Sure wouldn't mind a 1KZ-TE, I've researched those (also used in the venerable Hi-Lux I understand). But like many diesels, they were never sold in the US -- partly because of emissions regulations (which I won't complain about) and partly because US car buyers don't really understand diesels. Unless it's in a big truck, the diesel-powered cars we have here are almost always far outsold by the gasoline versions, so I think car makers don't have a big incentive to bring diesels to market here.
shane
