STD Maintenance General W124 300d turbo OM603 ticking noise under valve cover
justcruisin
02-21-2011, 01:28 PM #1
Helly everyone,
I've got a 300tdt w124 '92 with OM603 engine which has a loud ticking noise under the valve cover.
Have changed the oil from 5w30 to 10w40 and filter
Replaced the valve thingies (which are responsible for adjustment between camshaft and valves) under the camshaft.
Someone told me it could the headgasket so it loses oil pressure to the distribution.
Cold start gives a ticking noise when running, loudest around cil 2 and 3.
Warm engine loses the noise when revving high, 3000 rpm and up, valves are quiet till 10 seconds after revving.
Can anyone confirm the oil press loss problem due to a defective cil head gasket?
Thanks
This post was last modified: 02-21-2011, 01:30 PM by justcruisin.
justcruisin
Helly everyone,
Thanks
olefejer
02-21-2011, 01:54 PM #2
Yes it is a well know problem,
https://picasaweb.google.com/olefejer/W1...tToppKning#
There is a video before and after
olefejer
justcruisin
02-21-2011, 07:49 PM #3
Thanks Olefejer,
This is the info I was looking for.
Gr. Edwin
justcruisin
Thanks Olefejer,
Gr. Edwin
02-23-2011, 01:32 PM #4
Its basically the same symptoms I have. Having watched that first video in the link, sounds like it is dead on. There were a few headgasket revisions...
This post was last modified: 02-23-2011, 01:34 PM by winmutt.
jonbobshinigin
03-11-2011, 09:44 PM #5
I had a little bit of "lifter" noise when I first got the car, and now occasionally startup, but after switching to Mobil 1 Turbo Truck Synthetic, it is fine. Maybe not perfect, but close.
1987 300TDT - 260,000 Miles
jonbobshinigin
