1969 220D (added Turbo) vacuum governor problem
So, I decided my car was underpowered and thought that adding a turbo would be a good idea. I added a T3 turbo, I think, from a 300D, not to sure of the exact year of the turbo. I did all the mods I thought it needed and have discovered a very big problem. When the engine gets to somewhere around 3000 rpms, 220Ds don't have tachometers, the turbo boost causes there to be no back pressure, so the car continues to accelerate when I let off the pedal, and I have to kill the engine to stop it from running away. I've tried a couple of ideas to get the vacuum governor to work right at high rpms, but nothing seems to work. Oh, and it works properly at low rpms, its just when the boost really gets going that it won't stop accelerating. So, anyone have thoughts on how to remedy the problem?
Now that's an interesting problem... Does this engine have a throttle plate? Is the turbo before or after the plate in the intake system? If it's after, do you think that sampling vacuum between the plate and the turbo is possible?
If the plate is after the turbo, I don't think you have a chance.
(03-15-2011, 08:34 PM)E300TSC Now that's an interesting problem...Does this engine have a throttle plate? Is the turbo before or after the plate in the intake system? If it's after, do you think that sampling vacuum between the plate and the turbo is possible?
(03-15-2011, 05:08 PM)Larkston So, anyone have thoughts on how to remedy the problem?Put the throttle at the turbo inlet.
The Rayjay turbo kit showing how they relocate.
^ ditto
I have the rajay it on my 1980 240d and had to gut the throttle body's to make it work with the newer style injection pump!
if you want more detailed pics check out my 240 turbo thread http://www.superturbodiesel.com/std/old-...t-447.html
