STD Other FS / WTB / Buying guides Spring Cleaning Parts sale
03-22-2011, 02:08 PM #1
PM me for prices.
- NOS 616/617 IWIS Timing chain no master link.
-2nd Gen w126 Blue Dash with no air bag. No cracks. Pulled from a 420SEL. With a little work, I think it can be retro fitted to 1st Gen w126.
-w116 19mm rear sway bar.
-1984Cali and 1985 Federal 617.952 Air boxes
-617 N/A crankshaft
-617.95x turbo EGR exhaust manifold
-617.950 turbo non-EGR Intake and Exhaust manifold
-1985 300D Cali 617.952 down pipe. (goes up higher then Federal style)
-1980 300D N/A torque converter.
- 2qty 2.47 ratio w126 instrument clusters
-1qty w124 instrument cluster.
-3.07 ratio differential - 120,000 miles.
-617.952 Power steering pump
-2 qty 617.95x 9 blade plastic fan and clutch
-603 w124 300D radiator nissens.
-w123 front Passenger door - Champagne color from 1984 300D.
-2qty Untested a/c compressors. Visually look good, pulley turns, there is suction, and clutch engages with power.
- NOS w116 lower control arm bushing (one side only). In box, Febi 116 330 01 75
- NOS w124 rear parking brake shoes (left and right). In box, ATE 124 20 07 20
-NOS Remanufactured w126 V8 idle speed Unit - In box, 004 545 10 32
-Untested w126 V8 EZL - Bosch part number 0 227 400 600 and MB par number 003 545 92 32
-Good used w210 K40 relay - 210 540 00 72 from E320
- Blue w123/w126 rear headrest.
- used w123 FTE brake booster.
-617 valvecovers.
- w123 brake calipers ATE Front and rear, good core bodies but would have to be resealed.
- few good antenna masts
- NOS w201 washer tank. 201 869 10 20
-617 turbo fuel Injectors - Both core and visually serviceable units.
- Assorted bolts, switches and random stuff. PM me if your looking for something. I might have it.
This post was last modified: 03-22-2011, 04:12 PM by DeliveryValve.
PM me for prices.
-617 N/A crankshaft
-617 valvecovers.
dieselboy
Rotatin 5500 times a minute
680
03-22-2011, 03:52 PM #2
Let me measure my rear sway bar. If it's smaller than 19mm I may be interested in that. What 116 did the 19mm bar come on?
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
03-22-2011, 04:13 PM #3
(03-22-2011, 03:52 PM)dieselboy Let me measure my rear sway bar. If it's smaller than 19mm I may be interested in that. What 116 did the 19mm bar come on?
Caliper actually measured around 18.5 mm for the sway bar.
Your car should have it already.
300SD81
03-22-2011, 06:51 PM #4
How much for the non-egr manifolds?
Ich liebe meine Autos!
300SD81
676869addict
03-27-2011, 09:06 PM #5
can you give price on non egr manifold and valve cover shipped to 94509
thanks dave
676869addict
thanks dave
03-28-2011, 06:28 PM #6
(03-27-2011, 09:06 PM)676869addict can you give price on non egr manifold and valve cover shipped to 94509
thanks dave
PM sent.
thanks dave
PM sent.
