i need some other than bad news
After my brother used the car for about 200 miles, he brought it back with 2-3 quarts of oil left in the engine and a clanking noise. Every advice I heard was bad. I changed the oil and bottom oil pan gasket ( I was planning on it anyway) and still clacking that you hear more trough the exhaust pipe (straight 2") especialy when idling. What non-major things can I try before getting into more complicated things?
(03-28-2011, 07:42 AM)EuroBenz What non-major things can I try before getting into more complicated things?
Couldn't just be something simple, like a valve adjustment. I found some turbo diesel engines for sale, they just have unknown condition. The car still drives as strong as before, its just the noise....
You can try using a long screwdriver against your ear to isolate the location the noise is comming from, or just buy a mechanic's stethescope. First thing would be a full oil & filter change, maybe a bit heavier of viscosity. Even if it is scrap, you might get some time out of it to source an engine if the car is worth it.
Or just flog the hell out of it....
Ed
(03-28-2011, 08:19 AM)ForcedInduction(03-28-2011, 07:42 AM)EuroBenz What non-major things can I try before getting into more complicated things?
Straight-swapping in a new engine instead of trying to fix the fried one.
(03-30-2011, 10:12 AM)winmutt(03-28-2011, 08:19 AM)ForcedInduction(03-28-2011, 07:42 AM)EuroBenz What non-major things can I try before getting into more complicated things?
Head is cheaper and easier.
More than likely bent valve. Welcome to my world.
I say look for a turbo w123 on craigslist with a strong motor but tired body, and steal the drivetrain for your car.
(04-01-2011, 07:49 AM)winmutt I mean by swapping in a used head from the junkyard. Depend entirely on the price at the yard. Here it is about $50.
Valve adjustment?
I just saved a bunch of money on car insurance!
Most possible is an injector. If a nozzle drips or gets stuck open, it will knock like crazy. The technique I suggested in the previous post should show that. The knock should go away when line of the injector is loosened. The knocking caused by compression is called "nailing".I had a bad injector that came and went as I was driving before. Maybe that is what happened when it cleaned up for a few starts.food for thought if you end up breaking the motor down; had someone tell me about a motor nailing that ended up being a bad oil ring. The oil drawn into the combustion chamber was acting as extra fuel just like a bad injector. Also a bad injector usually has blue or grey smoke. You should pin point the knock, top or lower side. If on top, use a steth or screwdriver/round bar/broomstick like yankneck suggested. you will be able to hear a difference. Let us know what you find.
