Acetone in diesel
Acetone in diesel
sounds good to me, it's flammable. acetone is soluble in water and/or oil. go for it. I would bet up to 10% would be no big deal. Past that who knows.
this chart
http://www.engineeringtoolbox.com/specif...d_151.html
says acetone has a bit more energy per weight than kerosene. I don't know about by volume though.
Quote:Somebody told me wilt one cap full would increase the explosion by about 40%Ask him to be more specific, increased energy, or temperature, or flame front speed? And is he talking about mixing it with diesel or WVO or BD?
Quote:says acetone has a bit more energy per weight than kerosene. I don't know about by volume though.
Acetone is easier to ignite too much in a diesel engine and it will go bang the same as putting too much petrol in. I don't know if they still do it (doubtful) but in days gone by UK Taxi drivers used to put Acetone in during the winter to help cold winter starts and also to help stop diesel waxing. Its great stuff for clearing water out of tanks as well as, water mixes with it and it then mixes with diesel.
About a year ago, I tried adding acetone to #2 ULSD (ordinary pump diesel). I found that any quantity over about 15 ml acetone per 4 gallons of diesel, made the engine idle rough. At about 30 ml acetone per 4 gallons #2 diesel, I did feel a very, very slight increase in engine power at freeway speeds. On a local steep long hill straightaway, going up, I was getting 71 MPH at the top with 30 ml acetone per 4 gallons diesel, only 69-1/2 MPH without. This is just a single run each time. Perhaps air temperature and humidity had more to do with the difference than the acetone.
#2 diesel is wayyy too expensive nowadays --diesel has gone from $1.70 to $4.00 a gallon since Obama was inaugurated-- , so I burn a mixture containing 87% WVO.
Over the course of the last ~ 22,000 miles I have been experimenting with adding acetone to my veggie oil fuel mixture, because acetone, or, to be more precise, acetone in combination with turpentine, is an effective solvent for polymerized canola oil, which is like some kind of glue-y wax and so of course threatens to stick up everything in the fuel system between the fuel tank and the injectors.
I have found that 15 ml acetone per 4 gallons of canola oil, causes rough idle. But I can get away with 5 ml acetone per 4 gallons canola oil, and at 5 ml acetone the idle remains smooth.
Probably helps take any small quantity of stray water out of the tank too, just as Mark_M indicates, no matter whether you use #2 diesel or veggie oil as fuel.
But you are not going to see any significant increase in horsepower.
(08-09-2012, 12:53 AM)JustPassinThru #2 diesel is wayyy too expensive nowadays --diesel has gone from $1.70 to $4.00 a gallon since Obama was inaugurated-- , so I burn a mixture containing 87% WVO.
Funny, I remember paying $5.25 for diesel pre Obama
(08-09-2012, 07:19 AM)Simpler=Better Funny, I remember paying $5.25 for diesel pre Obama
Don't get me wrong, I'm not taking sides (all politicians lie) but damn-fuel is cheap these days. Back in 05 I was paying $3.20 for fuel, now it's $3.65...not too bad for 7 years later.
Not being a stickler to details, but Obama came into office on Jan. 20 2009.
Here is proof prices skyrocketed during the Bush administration.
http://forums.tdiclub.com/showthread.php?t=207230
(08-09-2012, 03:16 PM)DeliveryValve Not being a stickler to details, but Obama came into office on Jan. 20 2009.
Sort of off topic, but apparently some people don't even pay for diesel, like the people who came in the night sometime in the past couple days and pumped a couple hundred gallons (I'm guessing 3-400 maybe) out of one of my boss's tanks. I didn't really think people were that daring but I guess so...
(08-10-2012, 10:39 PM)sassparilla_kid Sort of off topic, but apparently some people don't even pay for diesel, like the people who came in the night sometime in the past couple days and pumped a couple hundred gallons (I'm guessing 3-400 maybe) out of one of my boss's tanks. I didn't really think people were that daring but I guess so...
