4 cyl perkins only firing on two cylinders at idle?
I have a 318 perkins in my "farm stock" pulling tractor. It has been bored and stroked to be almost 390 ci, also has a ground cam in it from crower. No head work except the angles on the valve have been touched up.
When at idle cylinders 1 & 2 do not fire, but when it is at WOT it runs fine?
Any input is greatly appreciated.
Id pull a injector line off a missing cylinder and do a ghetto jar timed cc test and compatr it ti a good cylinder If they are close then pop test the injectors.
Ve or inline pump?
(05-15-2011, 06:30 PM)dieselboy Ve or inline pump?
(05-15-2011, 12:57 PM)MFSuper90 When at idle cylinders 1 & 2 do not fire, but when it is at WOT it runs fine?
(05-16-2011, 09:28 AM)HoleshotHolset It's a pulling tractor, it's supposed to idle funny and then run like a recently violated primate at WOT...
recently violated primate... Jebus, I'm gonna steal that line from you. LOL My coworker was looking at me funny when I started laughing over here!
Have you checked leakdown on the cylinders?
(05-16-2011, 07:32 PM)Biohazard Have you checked leakdown on the cylinders?
John, It's direct injection.
As after I converted it to a VE pump it helped with the miss some.
But I think it's mainly from the big cam and wild timing
well its some time since I played with 4.318 but for me it sounds like the valves have you checked the valve clearance if you run std exhaust valves the beating and heat can make so the valves are going up in the head so there is no compression when its idle but at rpm they are forced up so it running on all 4
is it worse when its hot then its a possibility
I have seen it on a lot on old tractors where nobody have adjusted the valves for decades symptom to look for it more difficult to start when its hot.
Hansendlk, you were correct partially correct. Two valve were sunk into the head not seating correctly and the port job that was done had a pinhole in the intake side cause it to suck a tiny bit of coolant in the cylinder. And it had two bad injectors. I just got all this taken apart and check the past month or two lol.
It's changed some though, now it has a Bosch VE on it and I just fabbed up a Borg Warner s257sxe on it, waiting for my injectors to come back now...
