STD Tuning Engine Engine rubber mounts om617 turbo
BRABUS
05-31-2011, 09:03 AM #1
Hi
Is there any different engine rubber mounts for the om617 turbo/non turbo?
or are almost all 123 engine mounts the same? i see 617 without ac and 617 with ac use different rubber mounts?
Any ideas?
Going to buy new ones, and want them as stiff as possible.
BRABUS
Hi
Any ideas?
05-31-2011, 04:35 PM #2
As far as I know. Turbo w123 mounts are the same regardless of A/C. However, the Factory Service manual states part number 123 241 27 30 with one blue dot for the right mount and 123 241 40 13 with two blue dots for the left mount. I assume different properties are needed for side.
But if you ever order one online you get part number 123 241 13 30 used for both sides.
Phoenix brand is the OE manufacturer for 617 motor mounts.
http://www.rmeuropean.com/Part-Number/En...86561.aspx
Hercules
06-01-2011, 01:13 AM #3
Mbz. updated to all the same mount
Hercules
