STD Other Open Post yer non-MBZ rides
kamel
Naturally-aspirated SUCKS
176
03-12-2009, 12:39 AM #1
My '85 Chevy C20. 350 SBC, Muncie SM465 manual trans, Edelbrock carb. Workbody will be ditched for either a flat bed or pickup bed.
[Image: IMG_4252.jpg]
My old '72 Chevy C20, RIP. 350 SBC, Muncie SM420 manual, Edelbrock intake + carb, comp cam, heddman longtube headers to 3" summit mufflers.
[Image: DSC_9729.jpg]
My Pinzy Smile :
[Image: IMG_4232.jpg]
kamel
My Pinzy Smile :
03-12-2009, 03:01 AM #2
1998 Trek 700 multitrack. I've gotten it up to 55mph a few times.
This post was last modified: 03-12-2009, 03:03 AM by ForcedInduction.
03-13-2009, 12:48 PM #3
That pinzauer is a model right?
kamel
176
03-13-2009, 05:10 PM #4
Well, it's a 1/10 scale RC crawler. Custom, of course. Wink
kamel
Gross Polluter
03-15-2009, 02:52 PM #5
My non MBZ ride will technically be my MBZ ride. My Volvo 245 will eventually get an OM617, but that's a long term project. For the time being I'll rock the stock red block. Has close to 300k miles on it and each cylinder leaks at <9%.
[Image: IMG_4678small.jpg]
I recently sold my 88 RX-7 Turbo II. Unlike previous projects, I built this car to be well rounded. Even balance of power and handling.This car was also my first megasquirt project.
[Image: DSCF3858.JPG]
The car was fairly modded and being a Japanese car, cops were on the lookout. I tried to keep the engine bay as stock looking as possible.
[Image: DSCF3125.JPG]
Oh, and I installed HID's the right way. OEM nissan projectors fitted to the stock pop-up actuators:
[Image: DSCF3088.JPG]
My current non-daily driven project is a 68 Mustang 351c. I'm not really interested in restoring it, I'm not into making cars look good. It's been in the family for 20 years and when I acquired it, changes had to be made. First, the carb and distributor had to go:
[Image: DSCF2778.JPG]
With a few trips to the junkyard for ignition and fuel parts, an order from DIY autotune, and lots of fab time, I megasquirted the 351. Port fuel injection, wasted spark, single throttle body. The picture below was taken the night I started the car on the new setup. Since then I've fabbed an intake system for it.
[Image: DSCF2946.JPG]
Finally, my backup daily is an Infiniti M30. I've had the car since high school and it sort of just sticks around. It's worth less than $1000 and as reliable as the car is, I just can't get rid of it.
Gross Polluter
03-17-2009, 12:38 AM #6
(03-15-2009, 02:52 PM)Gross Polluter .....
Cleveland's are sentimental to me. Is that a 2v? I've seen people rework the 5.0L/5.8L injection and manifold to use on the Cleveland. This install looks a lot cleaner. Would love to see your new intake.
This post was last modified: 03-17-2009, 12:40 AM by DeliveryValve.
Gross Polluter
03-17-2009, 01:53 AM #7
It's a 2V. I used the intake manifold that was on there to begin with, an edelbrock performer. I machined injector bungs, and ports in the runners to fit th bungs into:
[Image: DSCF2884.JPG]
The throttle body adapter was fabbed for fit an Infinit Q45 throttle body and bolt it to the modified edelbrock manifold:
[Image: DSCF2921.JPG]
I'll have to update the gallery with some of the stuff I've done recently. The air filter no longer sits off the throttle body, there's a 3.5" 90 degree silicon coupler connected to a pipe that locates the filter next to the radiator at the grille. The distributor has also been completely eliminated. The oil pump is now driven by a custom shaft made from a stock distributor. The only thing you see now is a cap where the distributor used to be.
As far as the rest of the system goes
Fuel:
Bosch Motorsport "044" pump
Mercedes 450SEL fuel filter
-8 feed, stock carb line used for return
Mallory boost compensated FPR
Custom fuel rails from extrusion
2nd gen non-turbo RX-7 injectors, driven in peak-and-hold, 450cc
Ignition:
DSM coil packs
DSM power transistors
ACCEL DIY wire set for mopars
Computer:
MSII on a 3.0 board
MS2/E 2.0.1 Firmware
36-1 trigger mounted to crank
JAW wideband O2 controller
The stock 35 amp alternator was insufficient for all of the new electrical stuff. It just so happens that the 70amp second gen RX-7 alternators have the same mounts as old ford alternators, so it was a bolt in affair for an internally regulated 70amp alternator that cost all of 12.99 in the junkyard.
This post was last modified: 03-17-2009, 01:56 AM by Gross Polluter.
Gross Polluter
Fuel:
Ignition:
DSM coil packs
Computer:
MSII on a 3.0 board
03-17-2009, 07:45 PM #8
(03-17-2009, 01:53 AM)Gross Polluter It's a 2V. .....
How does it run on pump gas? Are you pinging?
(03-17-2009, 01:53 AM)Gross Polluter The oil pump is now driven by a custom shaft made from a stock distributor. The only thing you see now is a cap where the distributor used to be.
Would love to see a pic of that. I take it you just chopped it at the waist and kept the hold down clamp the same. i
(03-17-2009, 01:53 AM)Gross Polluter As far as the rest of the system goes
Fuel:
Ignition:
DSM coil packs
Computer:
MSII on a 3.0 board
Good job and Nice recipe.
Fuel:
Ignition:
DSM coil packs
Computer:
MSII on a 3.0 board
Gross Polluter
03-18-2009, 01:17 AM #9
On California 91 octane dish water it does not ping with 31 degrees in at the torque peak, 32 degrees at 5600 rpm to the rev limiter, 6250 rpm. Running 12.8 AFR's from the torque peak on until I get it on the dyno to fine tune it. I don't see low-mid 13 AFRs being a problem. Here's my current timing map until I get it on the dyno:
[Image: 351ctmg91oct.jpg]
I'll take a picture of the current setup tomorrow and post it up. For the oil pump drive the distributor body was cut at the base where it clamps to the block. The body was machined to fit a sealed ball bearing assembly to support the shaft and then a cap machined to fit the top of the body to retain the bearing. It's a trick assembly built by my father, he's a pretty talented machinist. I just do the sheet metal fab and welding. I'm not good at explaining things, when I post some pictures you'll get a better idea.
Gross Polluter
kamel
176
03-18-2009, 01:40 AM #10
AFR, eh? My buddy works there, maybe he can work some magic on a 617 head. Big Grin
kamel
Gross Polluter
03-18-2009, 06:48 PM #11
Setup as of today:
[Image: DSCF4559.JPG]
Oil pump drive:
[Image: DSCF4561.JPG]
The rest of the build pictures are in my gallery:
http://pictures.nsfabrication.com/v/cars/68stang/
Gross Polluter
Setup as of today:
Oil pump drive:
Thejoker
04-05-2009, 11:02 PM #12
She's my Project: [Image: IMG_2978.jpg]
[Image: IMG_2973.jpg]
[Image: IMG_2971.jpg]
This is about an Inch pushed in: [Image: IMG_2970.jpg]
The only reason it's my project is because I crashed it when I was Twenty One. What happened was, I was going to my house on a summer day for the guys to do the dry wall on my newly built addition. When I was going some woman with her husband IN the back seat. Her husband exclaimed when I was doing the turn "Go Go Go!", and she listened and I tried to steer away and she nailed me. So, I actually landed it good, but I fucked up my knee pretty bad. And if you think I was a rich little 21 year old kid you're wrong. I bought a foreclosure home and got the money to build over the first floor to make the Addition. Then now I've been living there for exactly 8 years. I rent out the first floor and live on the top. But anyways, here's my 1978 Monte Carlo which is a "Project Car":
1. [Image: IMG_2982.jpg]
2. [Image: IMG_2981.jpg]
Also, here's my Jeep sitting in my friends Driveway today picture from my friend Mark: [Image: IMG_2962.jpg]
That's all for my cars that aren't Mercedes Diesels, or Gas Mercedes Benz's.
Thejoker
Tymbrymi
Klatta Klatta
185
04-07-2009, 08:00 AM #13
All I've got is a '95 Mazda B2300. It was my first car, and I just can't seem to kill it!
[Image: IMG_0032.jpg]
[Image: IMG_2183.jpg]
[Image: DSCF0001.JPG]
[Image: DSCF0023.JPG]
John Robbins
Tymbrymi
John Robbins
kamel
176
07-04-2009, 11:17 PM #14
Got a new (to me) truck. The war wagon:
[Image: IMG_4693.jpg]
[Image: IMG_4694.jpg]
[Image: IMG_4700.jpg]
'76 chevy 1 ton crew cab. 4 speed manual, goodwrench 350, 10.5" 14 bolt full floating rearend. Perfect for draggin around my toys.
kamel
Diesel
07-06-2009, 06:56 AM #15
My bike which I need to ride more often
[Image: 3380035935_425c399686_b.jpg]
My daily ride.
03 Jetta TDi wagon GL 5spd
H&R springs, Koni shocks .205 injectors, boost & oil pressure gauges on the A-pillar.......probably get a Rocket-chip here soon.
[Image: 3274743431_cde8372c5d_b.jpg]
The project car.
73 220d 4spd
When I got it
[Image: 3124030550_5784c9eb8c_b.jpg]
[Image: 3124029768_a276ef8cf3_b.jpg]
Today
[Image: 3678498113_ac1c1c42d0_o.jpg]
[Image: 3678498447_5238790c1f_o.jpg]
[Image: 3678497769_d891671f65_o.jpg]
The other, other car
08 997s 6spd
[Image: 3536963457_0f1bd62ba5_o.jpg]
[Image: 3537775786_aef957ac33_o.jpg]
This post was last modified: 07-06-2009, 06:57 AM by Diesel.
Diesel
My daily ride.
The project car.
73 220d 4spd
When I got it
Today
08 997s 6spd
Telecommbrkr
Soon to be mod'ing......
97
07-09-2009, 09:33 PM #16
Diesel,
First off, Veeeerry nice Porche! drool, drool
Secondly, build some shelves and some benches man! You will be so much happier. It is worth the time you would take away from your project, really in one evening you could have a workbench where your compressor is, and your compressor could sit underneath. I just went into new housing developments and went through the construction dumpsters, they're throwing it out anyways. Lots of 2x4's and 3/4" decking that are perfect for bench building. The 3/8" OSB wall sheeting cut-offs make great shelf boards on top of 2x4 'boxes', with 2x4 legs.
Let me know if you need some quick sketches of quick-build, solid 2x4 shop furniture.
Oh yeah, here is one of my non-mbz rides.
1970 SS Chevelle #'s matching, all original, unrestored (but really needs one!)
Sitting in the pole-shed next to 'Jurgen'
In the Quanset getting ready for the 'resurection run' It had been in storage for the last ten years while we grew our little family, and now finally it is back in my possesion ON MY property!! Big Grin
Inside
Engine
The 'Resurection Run' I hadn't driven it for about nine years when this photo was taken two Easters ago. That's my youngest hangin out the window. She likes to 'Go faaaaaster Daddy!!!' Big Grin
Now for s**ts and giggles, I'll fill up the wee jerry-can (now in the trunk - original fuel tank pooched) and go for a blast down the back road. That one gallon can is good enough for two or three really good burnouts CoolBig Grin , and up and down the back road at high speed 'bout 4 miles total
Other rides include:
1972 Chev 1/2ton p/u
1972 Chev K5 Blazer
This post was last modified: 07-09-2009, 10:34 PM by Telecommbrkr.
Mods are in the works...
Telecommbrkr
Diesel,
Inside
Engine
1972 Chev K5 Blazer
07-10-2009, 09:29 AM #17
Thats a sweet ride with some work.
Telecommbrkr
97
07-10-2009, 06:53 PM #18
(07-10-2009, 09:29 AM)winmutt Thats a sweet ride with some work.
Aren't they all......!? Big GrinTongueCool
Telecommbrkr
Diesel
07-11-2009, 08:56 AM #19
(07-09-2009, 09:33 PM)Telecommbrkr Diesel,
Thanks!
(07-09-2009, 09:33 PM)Telecommbrkr Secondly, build some shelves and some benches man! You will be so much happier. It is worth the time you would take away from your project, really in one evening you could have a workbench where your compressor is, and your compressor could sit underneath. I just went into new housing developments and went through the construction dumpsters, they're throwing it out anyways. Lots of 2x4's and 3/4" decking that are perfect for bench building. The 3/8" OSB wall sheeting cut-offs make great shelf boards on top of 2x4 'boxes', with 2x4 legs.
I've already started, but could use your sketches if you've got them handy.
Nice Chevelle! A buddy of mine has a 69 that he's slowly getting the way he want's
Diesel
Thanks!
07-13-2009, 09:13 AM #20
(07-10-2009, 06:53 PM)Telecommbrkr Aren't they all......!? Big GrinTongueCool
Not if it says Yugo on the back. Although even those these days have such a cache.
cannonballSDL
CONTROL_agent21
66
08-05-2009, 11:11 AM #21
[Image: TBsig21.jpg]
and
[Image: lt_cross_600.jpg]
a few box trucks and a race car too lol
cannonballSDL
and
09-18-2009, 10:04 AM #22
1973 Ghia 4-speed-
1991 Miata 5-speed-
1995 Eagle Summit 5-speed winter vehicle, and best of the three for picking up dates-
This post was last modified: 09-18-2009, 10:05 AM by JB3.
1973 Ghia 4-speed-
1991 Miata 5-speed-
09-18-2009, 10:42 AM #23
Nice ghia. I saw a 60's Karmen porsche broken down on the side of the interstate. Was beautiful looking,
09-18-2009, 11:35 AM #24
nice summit!!!! miata's are fun some one needs a TDI in one tough
MB TECH
09-18-2009, 11:42 AM #25
1997 Chevy Tahoe 4X4 minor lift, 33" tires, rhino liner for an interior and lower part of exterior, intake and exhaust, drilled and slotted front brakes, five HID spot lights on roof, HID headlights, PIAA fog lamps, dual batteries, 200amp alternator, stereo, Posi rear diff, 175,000 miles owned it since 90,000. This is the reason I bought a 123 in the first place (fuel got expensive)
1979 450SEL 6.9 - stock
1960 220SE
2005 S55 AMG - stock
2006 SLK55 AMG - stock
MB TECH
1960 220SE
09-20-2009, 05:22 PM #26
I just picked up this sweet mga! 4 $650
here are some pics of rides I have sold
1957 supercharged Packard I got for $600
my 74 mg midget
1978 e12 BMW 530i
75 MGB I got for $250
71 land rover
71 Citroen DS 21
This post was last modified: 02-19-2010, 11:01 PM by willbhere4u.
my 74 mg midget
1978 e12 BMW 530i
71 land rover
71 Citroen DS 21
02-17-2010, 12:42 AM #27
Got an 05 Elise today with a forced fed 275hp turbo kit Big GrinBig GrinBig Grin and my very first car loan ever!!!Sad
This post was last modified: 02-19-2010, 11:05 PM by willbhere4u.
02-19-2010, 11:05 PM #28
I found out the Elise last dynoed at 250 RWHP o-60 in sub 4 seconds and 0-100 around 8 sec
but it looks like I have to sell the MGA now oh well it's a small sacrifice!
02-20-2010, 08:32 AM #29
holy shit! thats a very very nice car. How did you come across that? I don't even want to imagine what the monthly payments on something like that are.
Ill race you in 'grimace'-
300SD81
02-21-2010, 11:05 PM #30
Closest thing to another ride I got Big Grin you haven't experienced crowded until you try to get on one....
[Image: busj.jpg]
This post was last modified: 02-21-2010, 11:07 PM by 300SD81.
Ich liebe meine Autos!
300SD81
[Image: busj.jpg]
02-22-2010, 01:25 PM #31
It was sitting at a small used car lot next to an 1983 Subaru hatch. It was less than half of a new corvette and just as fast!!! It's also half as big!!!
boost_creep
02-25-2010, 01:34 AM #32
89 Lebaron
[Image: two.jpg]
89 Dodge shadow
[Image: shiny-1.jpg]
87 300td
[Image: benzbp1-1.jpg]
boost_creep
89 Lebaron
[Image: two.jpg]
89 Dodge shadow
87 300td
Rudolf_Diesel
Ask me if I care...
02-25-2010, 11:03 PM #33
My tow vehicle, 1995 f350, yea it's a "PowerJoke" as some would call it, but it I can tow a 28' fifth wheel and a 16' enclosed trailer and still go from 0-60 faster than your Mercedes Big Grin
Couldn't find an actual pic of my bike, but it looks just like this one - 2006 YZ250
Rudolf_Diesel
capflya
Dreaming of a VNT
309
03-25-2010, 04:39 AM #34
Don't have any pics of the benz's yet but here's my truck... If I could only get half the power of my truck into the 300D I think I would be happy (400/2 = 200RWHP Big Grin) but it would probably be short lived and I would want MORE MORE MORE! Big Grin
[Image: i93029.jpg]
This post was last modified: 07-22-2010, 09:45 AM by capflya.
capflya
[Image: i93029.jpg]
07-21-2010, 01:24 AM #35
Oops this is old but here is mine.
1972 GMC Sprint
2003 CRF450
2009 Buell 1125CR
'92 Miata - Rally car that lasted two months
1972 GMC Sprint
2003 CRF450
2009 Buell 1125CR
07-21-2010, 06:43 AM #36
I like miatas you murderous miata killer! Big Grin I see your rally car was a dreaded short nose crank miata, same problem mine may have had, very annoying. What happened to kill it? how in the hell did the hood come up like that?
[/align]
[/align]
07-21-2010, 02:38 PM #37
Well we go it as a freebie because this girls son had rolled it. One of the cam gears was broke, so we took the car and fixed the gear in about two minutes and had it running champion. While fixing the cam gear by buddy decided to step on the plastic radiator tank and cracked it. we got another radiator from another car and rigged it in there. (keep in mind we didn't give a flying F*&k about this car). The rigging came loose and we ran the radiator over after landing a jump lol. long story short, we decided to run it air cooled. It didn't like that too much and would smoke and snap, crackle, pop, like rice crispys. It resulted in melting the plug wires down into the head. Baahahahaha we laughed so hard and had so much fun! dug out the wires and replaced with new ones. and now it only has spark to 2 cylinders. So the ECU is only firing one side of the coil. Other than that she is good to go... still cranks and still has plenty of compression.
The hood? we bent up the edges to make wings! then we just ran it without the hood.
we also sawzaled off the windshield frame
(07-21-2010, 06:43 AM)dropnosky I like miatas you murderous miata killer! Big Grin I see your rally car was a dreaded short nose crank miata, same problem mine may have had, very annoying. What happened to kill it? how in the hell did the hood come up like that?
[/align]
Whats this short nose crank you speak of?????
I'll get a current pic of it tonight!
This post was last modified: 07-21-2010, 02:39 PM by Captain America.
[/align]
07-21-2010, 03:20 PM #38
(07-21-2010, 02:38 PM)Captain America Whats this short nose crank you speak of?????
There is a keyway on the crankshaft for the timing belt pulley. It uses a woodruff type key to hold the pulley in the correct orientation. Evidently on the early year engines, mazda had not provided enough of a seating surface for this woodruff key in the actual crankshaft, and the woodruff key was longer than the slot, so it could move out of position and damage the keyway, messing up the timing of the vehicle.
Fortunately, they are non interference, but unfortunately, there is almost no effective way to repair that except actually removing the crank and replacing it with a newer one. From what I understand, you can't even get the old type crank at all.
I have not had this specific problem, but apparently there have been a lot of people who have had extremely unusual running problems which are eventually attributed to the timing actually changing as the woodruff key moves around in the keyway.
07-21-2010, 06:05 PM #39
Hmmm good to know. The coil not firing is because of a bad ignitor I'm thinking....
07-30-2010, 12:22 PM #40
Hey Captain America I just picked up a 1967 Chevy sport van 108 with a 283 3 speed I can now hang out with the small block crowd! lol
07-30-2010, 02:22 PM #41
Yeah! They call it the "Small Block Posse" in New York lol That's where my boss is from. They set up 1/4 mile drags in the middle of the F'in freeway!
08-09-2010, 08:33 PM #42
here are some pics yes of my van lol Hey its got a great running 283 with a 3spd column shift manual!
and the last pic is close to what I want it to look like after I've got some cash
I just have to figure out how to lower it
This post was last modified: 08-09-2010, 08:38 PM by willbhere4u.
08-09-2010, 08:56 PM #43
oh baby, potential!
Lowering should be cake... Cut the front springs and lower the rear with blocks under the axle...
oh baby, potential!
08-10-2010, 02:35 PM #44
I would but It has leafs up front!
08-11-2010, 09:52 AM #45
(08-10-2010, 02:35 PM)willbhere4u I would but It has leafs up front!
No shit! It does!?! lol yeah thats easy too. Leafs in the rear also right?
08-11-2010, 12:19 PM #46
Yea it has a solid front axle beam with leafs all the way around
I'm ok with the way the back sits
The front sits up nose happy! I'm thinking swamping the axle on top of the springs would be to extreme! It also has a weird wedge shapes spacer that looks important for the camber?
I was thinking of removing a leaf or two out of the front???
unless there is a drop spindle available of some sort?
08-11-2010, 02:21 PM #47
What if you shortened the shackles???
08-11-2010, 03:39 PM #48
It doesn't have any shackles up fornt
here are the pics of how this guy lowered his
08-17-2010, 02:11 PM #49
sorry hears the link http://dkm.smugmug.com/gallery/1278845/5...2700_ihHEA
either this or make up some kind of multi link set up with air bags!
98taco3
08-20-2010, 04:05 PM #50
ive got a few!
2000 2500 cummins (picture from the stealership i got it from)
[Image: side.jpg]
1974 dodge charger 440
[Image: car-ext.jpg]
[Image: 440-2.jpg]
73 Opel GT thats destroyed right now. started a drag car project and lost my job so she lives in the back yard now...
[Image: Picture001-2.jpg]
1953 Dodge M37 powerwagon
[Image: IMG_0850.jpg]
[Image: IMG_0849.jpg]
Used to have this but sold it to get the powerwagon. 84 4 runner with custom suspension i built. Rebuilt it from the ground up, and no it wasnt chrome for very longBig Grin Never let your roommate give you free paint if he gets to choose the color!
[Image: 100_0327.jpg]
[Image: 100_0326.jpg]
[Image: downsized_0324091848.jpg]
and my last pickup before it was wrecked...
[Image: slickrockbig.jpg]
98taco3
ive got a few!
[Image: side.jpg]
[Image: 440-2.jpg]
