STD Tuning Drivetrain heavy "clunk" when going into 1st when slowing down.
randomdude
06-25-2011, 07:16 PM #1
when i slow down to a stop, when it downshifts into first, i get a fairly heavy "clunk". the car does generaly shift a bit hard into second, and has a slight flare into 3/4. all which seems to be standard fare for these trans when they get a few miles on them. correct assumption? would a filter/flush/fill help? im sure i need to get the Msource pressure/setup kit and adjust it.
man that spring kit from smokedog&kens looks real nice, and sounds like it alleviates most of these issues. do you have to take the trans apart to install that?
thanks in advance Big Grin
cars? what cars? WHERE???
randomdude
06-25-2011, 08:31 PM #2
vacuum line is connected to the trans and VCV?
led-panzer
06-25-2011, 08:38 PM #3
The clunk is the driveshaft center support. Very good idea to replace it soon, if it breaks completely you won't be going anywhere over 15mph ask me how I know Big Grin
1985 300D 280,000 miles RIP
led-panzer
randomdude
06-25-2011, 10:43 PM #4
good info! thanks.
where is the vcv please? and where should it connect at the trans? (my first benz).
randomdude
good info! thanks.
06-25-2011, 11:23 PM #5
[Image: VCV_3044.jpg]
I believe the vacuum line going to the top tees and one leg goes to the trans modulator.
find a good picture of the modulator somewhere
http://www.google.com/search?q=w123+tran...24&bih=495
It's tight between the body and trans. On the driver's side where you can just barely reach up to it and slide on the vacuum line or make a pressure adjustment.
randomdude
06-26-2011, 02:14 AM #6
hrmmm sounds VERY interesting. does ANYONE have experiece with the MSOURCE adjustment kit then?
randomdude
randomdude
06-30-2011, 02:02 PM #7
is there any other things it could be? is my transmission going to blow up? lol
randomdude
led-panzer
06-30-2011, 04:38 PM #8
Did ya crawl under and look at the center mount?
led-panzer
