STD Tuning Engine Are there any differences between IP from 603 with auto and 603 with mechanical gearb
Savitas
06-28-2011, 11:16 AM #1
Hi guys,
are there any differences between IP from 603 engine with auto and 603 engine with mechanical gearbox?
Thanks
Savitas
Hi guys,
Thanks
aaa
06-28-2011, 11:25 AM #2
Yes. There's the ARA/jerk control. I'm not sure what it does, it's a solenoid that looks just like the ELR solenoid.
aaa
Savitas
06-28-2011, 11:34 AM #3
(06-28-2011, 11:25 AM)aaa Yes. There's the ARA/jerk control. I'm not sure what it does, it's a solenoid that looks just like the ELR solenoid.
Does it play big role if I'm going to use this IP on my OM606 engine? I'm going to use mechanical gearbox. Also 7,5 mm elements will be fitted in this IP.
This post was last modified: 06-28-2011, 11:34 AM by Savitas.
Savitas
06-28-2011, 12:00 PM #4
ARA/jerk control keeps the off idle jump smooth.
06-28-2011, 12:36 PM #5
Did you set one up after your 5spd swap on your 300d
Savitas
06-28-2011, 02:56 PM #6
(06-28-2011, 12:36 PM)willbhere4u Did you set one up after your 5spd swap on your 300d
5spd gearbox which goes with m57d30 engine, it can handle 600 NM.
Savitas
07-01-2011, 04:28 PM #7
If you were asking me, no I did not. The jerk in anti jerk is the ahole with the foot on the peddle. He/she can control that jerk with the clutch.
